knocking noise when braking
Old Aug 11, 2008 | 01:42 PM
beige89civic's Avatar
* B A N N E D *
Default knocking noise when braking
Knocking/ rubbing noise when coming to complete stop. I've replaced rf upper control arm it was loose. I machined my rotors checked all front end parts. Everything is tight. Pads aren't loose or anything. It only happens when coming to a complete stop. sounds like its in the left front area.
Help is always appreciated. Yes I tried the search function.
Thanks
Old Aug 11, 2008 | 05:00 PM
innes887's Avatar
double check that the sway bar bushings are good and tight and dont have any play in them.
Old Aug 11, 2008 | 07:48 PM
vtecb18c's Avatar
Default Re: (innes887)
motor mount possibly ?
Old Aug 12, 2008 | 03:52 PM
* B A N N E D *
Default Re: (vtecb18c)
I'll double check the mounts. They seemed ok. It happens when coming to a complete stop though.no load on engine or driveline. Once I get a rack open at work I'll pick it up and double check everything. I'm thinking lower ball joint maybe. somethings still knocking over bumps perhaps the sway bar as previously mentioned.
Old Aug 12, 2008 | 04:31 PM
Tyson's Avatar
Default Re: (beige89civic)
seems more likely a balljoint issue. double and triple check every bolt tho.
Old Aug 13, 2008 | 12:00 AM
FOMULA91's Avatar
Default Re: (Tyson)
I probably have the same issue. It makes a pop sound when you slow down to a complete stop. I replace the whole hub assembly with an DA Integra one but if it still makes the same noise, it's probably one of the ball joint since mines shot.
Old Aug 13, 2008 | 07:38 AM
drummingpariah's Avatar
Default Re: (FOMULA91)
This may seem like a no-brainer, but make sure your brake pads and calipers are secured. My rotors had about 1/2" of wiggle room and caused an awful racket when I came to a complete stop, then sometimes when I started again.
Old Aug 13, 2008 | 07:58 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Default Re: (drummingpariah)
Have some one outside of the car and have them tell you exactly where.
Old Aug 13, 2008 | 08:01 AM
B16-CRX's Avatar
Steering rack end bushing? mine had the same symptoms. You would feel it in the steering though..
Old Aug 13, 2008 | 12:14 PM
rexfan's Avatar
Default Re: knocking noise when braking (beige89civic)
i have the same deal.. do you have an aftermarket crossmember? I have always thought that it was my rods connecting to the crossmember
Old Aug 13, 2008 | 01:14 PM
Creator's Avatar
Default Re: knocking noise when braking (rexfan)
If it's your crossmember you should make sure those bolts are nice and tight and it should solve that problem. After I put my IM cross member on it started poping a few weeks later, went back and the bolts had loosened up. It's working just fine now...
OP I doubt that this is your problem
Old Aug 13, 2008 | 07:10 PM
* B A N N E D *
Default Re: knocking noise when braking (Creator)
Yes the calipers are tight. Pads do not float. I've yet to check on it again. Busy at work today. When you guys say cross member which one are you talking about? the one under the radiator that the radius rods connect into? Nothing on my car is aftermarket or modified with other parts from other honda's or anything of that nature.
Old Aug 14, 2008 | 09:23 AM
B16-CRX's Avatar
Jack up the front of your car and check for play in the suspension. you should also be able to feel if the radius arm bushings are shot.
Old Aug 15, 2008 | 05:45 AM
Creator's Avatar
As I stated I don't think this is what is causing your noise but, yes it is the piece you are referring to.
Old Aug 15, 2008 | 03:59 PM
* B A N N E D *
Figured it out finally. Strut arm bushings worn out making the lower control arm rub on the steering gear cradle. A trip to the honda store and $35 later got 4 strut arm bushings, 2 collars and 2 lock nuts. Replaced all the bushing stuff and what do ya know. It pulled that control arm back to center and cured the knocking/banging noise over bumps and when braking. I do wanna replace the lower control arm bushings though since it moved, but thats another day. I think B16-CRX's reply to this (radius arm bushings), could've helped out if I logged on and read this post earlier but I was busy.
Thanks for the help!!
shermanyang
Honda CR-V & Element
Apr 18, 2014 02:05 PM
Dunks
12
Jan 6, 2014 08:42 AM
accord2civic2prelude
Apr 27, 2009 08:46 PM
int3gra07
Dec 3, 2006 01:45 PM
ScorpioX
Jul 17, 2005 08:29 PM
