clutch wont disengage and go in gear! need help!!! searched!
Old Aug 11, 2008 | 12:49 PM
yc_dc4mar's Avatar
Default clutch wont disengage and go in gear! need help!!! searched!
ok so yesterday i finished putting my motor in. i start and push the clutch down and it stays to the firewall, no pressure. so we bleed the lines and get it all set up. its good now the pedal feels great. so i try again, and now it wont go in gear! i tried several times, even bled the clutch a few more times and it still wont go! i look at my slave cyl and its not straight lined up with the fork. i put some washers there as a spacer to see if that fixes it because it looked like its not pushing the fork enough to disengage the clutch..STILL NOT WORKING! i need help!!
Old Aug 11, 2008 | 12:51 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Maybe you need a new slave cylinder. Your clutch is definitely not dis-engaging, which is keeping you from getting it into gear.
Old Aug 11, 2008 | 01:50 PM
yc_dc4mar's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe you need a new slave cylinder. Your clutch is definitely not dis-engaging, which is keeping you from getting it into gear.</TD></TR></TABLE>
you think so? it almost wants to go..the car will slowly creep but it wont go into gear unless i slam it really hard.will i have to bleed my clutch lines all over again...that took forever! i put in a new clutch, pressure plate and flywheel too. and i know i put those on right. where can i get a new slave cyl from?
Modified by yc_dc4mar at 2:55 PM 8/11/2008
Old Aug 11, 2008 | 01:56 PM
yc_dc4mar's Avatar
Default Re: (yc_dc4mar)
the slave cyl moves the fork, just not enough i think..like only a cm.
Old Aug 11, 2008 | 02:00 PM
superfast666's Avatar
could be a flywheel bolt is loose and wont let the pressure plate engage happened to me before
Old Aug 11, 2008 | 03:50 PM
yc_dc4mar's Avatar
Default Re: (superfast666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superfast666 &raquo;</TD></TR><TR><TD CLASS="quote">could be a flywheel bolt is loose and wont let the pressure plate engage happened to me before</TD></TR></TABLE>
i dont see how this make sense? i dont think this is the problem though. i torqued them down pretty tight im sure.
Old Aug 11, 2008 | 04:35 PM
yc_dc4mar's Avatar
ok so i got new slave cyl and this is how it looks its doesn't make sense to me but its crooked.
it was like this with the old one too. here's what it would look like if it was straight from underneath the car.
when i bolt it up its crooked. wtf.. i know the fork is in right. from above.
Old Aug 11, 2008 | 05:19 PM
Community Builder
Pretty sure that release fork is nowhere NEAR being in far enough. Is it even engaging the TO bearing? If it is, are you sure that's the right fork for that transmission? Are sure that's the right slave cylinder?
The release fork can sometimes be difficult to get on the little pivot ball correctly. The spring on the back side of the fork has to get on there just right for it to stay and operate properly. Are sure you got the fork completely seated on the pivot ball with the spring capturing the pivot ball on both sides?
Old Aug 11, 2008 | 05:25 PM
yc_dc4mar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Pretty sure that release fork is nowhere NEAR being in far enough. Is it even engaging the TO bearing? If it is, are you sure that's the right fork for that transmission? Are sure that's the right slave cylinder?
The release fork can sometimes be difficult to get on the little pivot ball correctly. The spring on the back side of the fork has to get on there just right for it to stay and operate properly. Are sure you got the fork completely seated on the pivot ball with the spring capturing the pivot ball on both sides?</TD></TR></TABLE>
i know i did the fork properly i made sure of it bec it was sticking out even more the first time and i had to drop the tranny and do it again. the bearing hooks to the fork right...idk if its the right fork though....it came with the tranny when i bought it from a friend and worked the first time..but now after i put in this engine everything seems to be off. its the right slave cyl. i got it from napa auto parts for gsr. which is the tranny that i have. maybe its the wrong fork then..but how could it have worked b4 and not now?
Old Aug 11, 2008 | 05:48 PM
yc_dc4mar's Avatar
does anyone know the part number or official name of the fork that pushes the pilot bearing?
Old Aug 11, 2008 | 05:49 PM
yc_dc4mar's Avatar
does anyone know the part number or official name of the fork that pushes the throw out bearing?
Old Aug 11, 2008 | 07:38 PM
from that pic it dosent look like the shift fork is installed properly
Old Aug 11, 2008 | 09:25 PM
yc_dc4mar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superfast666 &raquo;</TD></TR><TR><TD CLASS="quote">from that pic it dosent look like the shift fork is installed properly</TD></TR></TABLE>
it is i made sure of it...are d-series longer? does anyone know? it might be a d series one because i got it from a friends who had a few civics and so idk if he knows he gave me the right one or not.
Old Aug 11, 2008 | 09:31 PM
it goes d series then b series is longer than h and f series is longer than the b maybe you have a h series shift fork in there
Old Aug 11, 2008 | 09:43 PM
yc_dc4mar's Avatar
hmmm wtf..i dropped the trans again today and it looked perfectly in there...i hate doing this.
oh and why is it, that when i remove the slave cyl from the trans, just unbolt it..not remove the lines...that the pedal gets soft again and feels like there is no pressure when i put it back on???
Old Aug 12, 2008 | 11:18 AM
yc_dc4mar's Avatar
Old Aug 12, 2008 | 11:20 AM
yc_dc4mar's Avatar
ok so i looked at my friends integra and his fork is much shorter than mine. i made sure mine was in right so im sure i have the wrong one..does anyone know the part number or know how i can get the part number?
Old Aug 12, 2008 | 11:25 AM
thats what i said
Old Aug 12, 2008 | 11:26 AM
yc_dc4mar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superfast666 &raquo;</TD></TR><TR><TD CLASS="quote">thats what i said</TD></TR></TABLE>
i know..lol do you know how i can get the part number?
Old Aug 12, 2008 | 12:00 PM
http://www.oemacuraparts.com/p...gid=0
Old Aug 12, 2008 | 04:35 PM
Community Builder
well it's not going to feel like there's any pressure until the slave is actually pushing on the fork, which pushes on the pressure plate. That's what gives the pedal the feeling of having "pressure" in it.
Old Aug 12, 2008 | 06:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">well it's not going to feel like there's any pressure until the slave is actually pushing on the fork, which pushes on the pressure plate. That's what gives the pedal the feeling of having "pressure" in it.</TD></TR></TABLE>
did you read any of the other post it was the wrong shift fork
Old Aug 13, 2008 | 05:19 AM
Community Builder
I know that, I was replying to him asking why the pedal was soft when he unbolted the slave but didn't remove the hard line.
Old Aug 14, 2008 | 03:25 PM
yc_dc4mar's Avatar
ok so yeah definatly the wrong fork.. top one is bseries i ordered from honda for an si for $50!!!! idk what the bottom one is but its HUGE!
thanks for all your help guys! much appreciated
Old Aug 14, 2008 | 10:54 PM
yc_dc4mar's Avatar
ok so i replaced the fork. IT STILL WONT DISENGAGE!!!!! idk wtf else i can do..i've just about had it with this thing! worst car ive ever owned and has giving me more problems in one day of having it than most would in a life time!
