Aftermarket Intake Manifolds
Old Aug 11, 2008 | 11:36 AM
fisherboy1118's Avatar
Default Aftermarket Intake Manifolds
If I bolted a Skunk2 manifold on a b18b1 would i need my car tuned for it? thanks for any help.
Old Aug 11, 2008 | 11:40 AM
neardon's Avatar
I'm a Jackass
You should have it tuned but its not worth the money if you just have a couple boltons. Dont expect any power gains either, maybe just a louder intake.
Old Aug 11, 2008 | 04:20 PM
Sentra's Avatar
Default Re: Aftermarket Intake Manifolds (fisherboy1118)
Right, i'd recommend just waiting on getting tuning done until you at least got all your bolt-ons taken care of.
Old Aug 13, 2008 | 07:47 AM
JdmTypeRdc2's Avatar
if anything an aftermarket intake manifold, like the skunk2, will hurt your performance if you have stock internals.
Because so much air is flowing into the motor, you would need bigger cams and upgraded fuel. Bigger cams usually call for more compression, so pistons should also be considered...
without all those supporting mods, the intake manifold will clearly just bog down the car.
dragula
Nov 3, 2011 04:51 PM
charlieboyhonda
16
Mar 19, 2008 11:18 PM
94SuperLudeSI
Feb 6, 2006 03:00 PM
b18cInside
Jan 7, 2003 09:26 AM
B00ST2nR
Mar 23, 2002 11:40 PM
