89 civic won't start
Old Aug 11, 2008 | 11:30 AM
89civicguy's Avatar
Default 89 civic won't start
Hey Im new to the world of hondas I just bought a 1989 civic DX with the D15B2 When I bought the car it needed the distributor installed so I did that and put a new rotor button in it since it was missing. The car started up just fine and I drove it home. On the way home it started to sputter and almost stall out. I thought this might have been bad fuel so I put some good fuel in it and it started up and made it home. Now it won't start at all. I had the ignition coil checked it came back fine and i put a new ignitor in as well and still nothing. I read online to check the engine codes but when I turn the ignition to the II position the little LED doesn't do anything at all. no blinks or anything. The ECU fuse(15amp) under the hood appears to be ok. Now I am at a loss as to what to do. Any help would be greatly appreciated and I hope I gave enough information about symptoms and what not. Thanx!!
Old Aug 11, 2008 | 12:23 PM
Gus-Gus's Avatar
Main relay or blown fuse?
Old Aug 11, 2008 | 04:16 PM
beige89civic's Avatar
* B A N N E D *
Default Re: 89 civic won't start (89civicguy)
Did you put a aftermarket coil and ignitor on it?
Old Aug 11, 2008 | 07:09 PM
89civicguy's Avatar
Default Re: 89 civic won't start (beige89civic)
everything is stock, i had the coil tested it checked out ok and i replaced the ignitor and still nothing
Old Aug 11, 2008 | 08:09 PM
civicmulisha's Avatar
are u sure ur getting spark from the plugs and r u getting fuel i would check those two things first before u give up lol and if i is a fuel issue it can be A the pump or B a clogged fuel filter if u need any help my myspace is http://www.myspace.com/ilovemandabear
Old Aug 11, 2008 | 08:38 PM
89civicguy's Avatar
Default Re: 89 civic won't start (civicmulisha)
checked fuel definately getting fuel but no spark whatsoever. i tried to check fault codes on ecu and nothing showed up at all no single blink or anything like i have read that it is supposed to do
Old Aug 12, 2008 | 03:57 PM
* B A N N E D *
what color is the coil? If its brown it's probably bad. Look for burnt trails of carbon. You can ohm the coil and it'll be within spec but still be bad.
Old Aug 15, 2008 | 05:08 PM
89civicguy's Avatar
found out that it was the main relay under the dash its running again!!!
Old Aug 17, 2008 | 05:06 AM
* B A N N E D *
It's running again????
MechEng
Oct 26, 2013 01:25 AM
teg your it
Aug 23, 2010 03:01 PM
89civicguy
Mar 1, 2009 08:22 PM
904d
Mar 23, 2005 09:41 PM
94_CRVtec
Jan 6, 2005 11:48 AM
