K-PRO is it worth it for an ep3
I have an ep3 with an exhaust and a short ram k&n intake. what kind of power would i gain and would i lose mpg. is it worth it. sorry if this is ignorant.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hasbro »</TD></TR><TR><TD CLASS="quote">There's a thread running write now that is the same queery. It's title is: K-PRO. </TD></TR></TABLE>
thats more towards a RSX-S though.
Honestly, save yourself $550 purchase price + tuning costs and just get the reflash. It'll be 75%+ of the power and cost a ton less.
You will have to tune the K-Pro. You won't have to tune the reflash.
The reflash made a ton of difference on my old EP3 in both power and drivability.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">
thats more towards a RSX-S though.</TD></TR></TABLE>
^What is the difference?
Would using regular gas negate the use of the reflash?
EDIT: ^ I called a dealer about my question and he said it would induce knock with regular. Theoretically, with the motor running leaner and more hp, one could drive with a lighter pedal for efficiency- if one so desired.
So, what is my point? Most of the time I drive efficiently but want the higher rpm. I was wondering if the extra price of premium could be justified with higher mpg. Not sure if it would but it helps me rationalize in favor of the K-Pro.
Modified by Hasbro at 3:26 PM 8/12/2008
Modified by Hasbro at 3:26 PM 8/12/2008</TD></TR></TABLE>
It's been dyno-proven that even the OEM EP3 ECU will compensate for premium gas and add a few HP.
With the reflash, you *must* run premium gas due to the adjustments the program makes.
And yes, in most cases premium will give you a slight bump in MPG. But is it enough to warrant the extra price? Only testing will tell.
One is a K20A2 one is a K20A3....
Some people may not consider it "worth it" on a K20A3.
Some people may not consider it "worth it" on a K20A3.</TD></TR></TABLE>
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 »</TD></TR><TR><TD CLASS="quote">
And yes, in most cases premium will give you a slight bump in MPG. But is it enough to warrant the extra price? Only testing will tell.</TD></TR></TABLE>
Hmm, 3.5 mpg more and that would nuetralize the extra 20 cents.
Thanks
RsxType-Stitch
16
Sep 7, 2005 07:52 PM
