GSR cams in 1st gen B16???
ok, these cams are cheap..60 bucks a set. are they worth it to upgrade from the dookie 1st gen b16 cams? is it a straight out swap? do i need the gsr cam gears? thanks for the help!
has anyone actually done this? are there any negative effects, such as erratic idle or loss of low end power? thanks!
yes, I put a set of these in a friends B16 powered EF long time ago. The cams showed better overall torque & HP over the stock B16 cams. Its worth doing if all you can afford are those cams vs. type-R cams.
juicy.koreans.suck
Mar 7, 2002 07:29 PM
