i need help if everything bolts up and if all the wiring is the same??
I have a 92 prelude that has the single cam f22a1. and i am going to buy the f22b dohc long block....i was wondering if someone knows if everything will be the same??? or if i am going to need to buy any other parts???? for the swap??
Well, you're going from SOHC to DOHC so consider that. Check out the FAQs for the swap threads.
