Suspension & Brakes Theory, alignment, spring rates....
Ground Control coilover install info
Old Aug 10, 2008 | 08:27 PM
JDM_Honda_349's Avatar
Default Ground Control coilover install info
When installing ground controls on a 95 civic, which sleeve goes on the front, the tall sleeve or shorter sleeve?Also, what about springs?Does the stiffer spring go on the front or rear?Thanks
Old Aug 11, 2008 | 01:20 PM
Tyson's Avatar
Default Re: Ground Control coilover install info (JDM_Honda_349)
the taller sleeve with the unthreaded portion goes in the rear shock so it fits inside the spring cup.
stiffer spring normally goes up front.
hawaiieg6
Suspension & Brakes
Aug 9, 2009 08:26 PM
lilo_goki
16
Mar 10, 2008 10:16 AM
TylerC161
Mar 28, 2007 06:17 PM
enrique
Apr 28, 2003 12:09 PM
HybridGSR1
Sep 23, 2002 01:58 AM
