h23 swap?
Old Aug 10, 2008 | 07:41 PM
mrspeedy69's Avatar
Default h23 swap?
My buddy has an H23 with an auto tranny and he is wanting to put it in either a crx or a hatch. Just curious if anybody has done this and if it's harder than any other swaps?
Old Aug 10, 2008 | 07:48 PM
D16SiHatch's Avatar
Default Re: h23 swap? (mrspeedy69)
yes h-series swaps have been done in an ef chassis, and yes they are also harder than a b-series. They're a good bit larger and take up more engine room, of which is already very minimal to begin with. the alt. has to be relocated. and it won't even begin to fit underneath a stock hood.
Old Aug 10, 2008 | 07:57 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: h23 swap? (D16SiHatch)
The auto tranny if he's planning on keeping it will remove the possibility of running one of the off the shelf mount kits and will take even more work.
It's not terribly hard to do a H swap but it's not the easiest either.
Old Aug 11, 2008 | 04:46 AM
mrspeedy69's Avatar
Alright thanks, he's never done a swap so i imagine it won't go so well.
Old Aug 11, 2008 | 05:50 AM
2point2's Avatar
Default Re: (mrspeedy69)
http://www.hasport.com/tech/installs/efh1.pdf
instructions.
The auto tranny is quite large and will probably be a stumbling block. Anything can be done however.
Old Aug 11, 2008 | 08:34 AM
kyle1jzsupra's Avatar
might as well just sell the h23 and get a h22. if hes gunna spend all that hard work on the swap he might want a lil more hp.
Old Aug 11, 2008 | 08:46 AM
Gus-Gus's Avatar
You also have to have good suspension and axles since the H-serise are heavy.
Old Aug 11, 2008 | 09:00 AM
gator88's Avatar
Default Re: h23 swap? (Gus-Gus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gus-Gus &raquo;</TD></TR><TR><TD CLASS="quote">You also have to have good suspension and axles since the H-serise are heavy.</TD></TR></TABLE>
here we go..the weight comment.
They aren't a whole lot heavier than a b series. people talk like an h series is an iron diesel block going in. far from true.
Old Aug 11, 2008 | 09:05 AM
JustAnotherRex's Avatar
Default Re: h23 swap? (gator88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gator88 &raquo;</TD></TR><TR><TD CLASS="quote">
They aren't a whole lot heavier than a b series. people talk like an h series is an iron diesel block going in. far from true.</TD></TR></TABLE>
Roughly 50 lbs last I'd heard, so no, not much.
Old Aug 11, 2008 | 10:56 AM
Eaglekper0046's Avatar
Default Re: (kyle1jzsupra)
If he was smart he would keep the h23 bottom end and get an H22 head. GET RID OF THE AUTOMATIC!!
Old Aug 11, 2008 | 11:02 AM
1.8 HAMSTER EF's Avatar
putting a h22 head on a h23 bottom end is not like doing a b16 on a ls lot of work
slinky1245
Jun 14, 2012 01:35 PM
aftershock2686
Jul 3, 2007 06:16 PM
sfarrell12
Aug 8, 2005 09:23 AM
4thgenlude
Aug 8, 2004 09:34 PM
D16Z6racing
Jan 12, 2004 11:21 AM
