HF vs. Si suspension??
Old Aug 10, 2008 | 06:16 PM
EDawg's Avatar
Default HF vs. Si suspension??
what are the differences between the suspension components of an HF vs. an Si?? i'm not talking about the shocks/springs, but the actual suspension arms, etc. i found a rear sway bar from an Si at a junkyard and was going to use it on my HF, but i realized that there is no treaded hole on the rear lower control arm to attach the sway links. are there differences between the 2 suspensions, and if so, what are they?? also, are the front sways on the HF and Si the same diameter??
Old Aug 10, 2008 | 06:20 PM
mit7059's Avatar
Default Re: HF vs. Si suspension?? (EDawg)
I think the only main difference is that the front sway bar on the Si is a couple of mm wider, and only the Si came with the rear sway and mounting holes. If you want to install the rear sway bar you can either ghetto rig something or swap the entire trailing arms from the Si. Also I think the 88 model year had a slightly different rear suspension then the rest of the EFs. I don't know exactly what was different though.
Old Aug 10, 2008 | 06:52 PM
Intocable's Avatar
Default Re: HF vs. Si suspension?? (mit7059)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mit7059 &raquo;</TD></TR><TR><TD CLASS="quote">I think the only main difference is that the front sway bar on the Si is a couple of mm wider, and only the Si came with the rear sway and mounting holes. If you want to install the rear sway bar you can either ghetto rig something or swap the entire trailing arms from the Si. Also I think the 88 model year had a slightly different rear suspension then the rest of the EFs. I don't know exactly what was different though.</TD></TR></TABLE>
I think its the LCA thats different on the 88
Old Aug 10, 2008 | 08:19 PM
Vinceg99's Avatar
Default Re: HF vs. Si suspension?? (Intocable)
The only thing that was different is the rear LCA's you can take that out of an Si (as long as its not an 88) and bolt them right into your HF you do NOT have to swap out the whole trailing arm.
And yes the 88 Si's have a different type of LCA's than any other they have LCA's like the Type R however those will also bolt right into your HF but you would need different shocks and you still wouldnt be able to use that sway bar.
If you can go back to that junkyard and get those LCA's from the Si you took the sway bar from.
Old Aug 10, 2008 | 08:26 PM
mit7059's Avatar
Default Re: HF vs. Si suspension?? (Vinceg99)
Whoops sorry about the bad advice about the trailing arms
Old Aug 10, 2008 | 11:30 PM
EDawg's Avatar
thanks guys. i'll go back to the junkyard to see if the Si is still there and take the lower CA.
Old Jan 13, 2009 | 07:22 PM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
*edit for clarity*
I just want to get new lower control arms for my HF (90-91) because they are worn out. I am not in need of a rear sway bar. I can get Blox or whatever is on ebay, right?
Old Jan 13, 2009 | 08:57 PM
EFRue57's Avatar
even if you got the lower control arms it's not gonna help. on the Si's an DX's there are threaded holes to mount the sway bar brackets on the chassis itself. These holes are not on the HF chassis.
Old Jan 14, 2009 | 03:30 AM
Not interested in a sway bar atm. Hence I put the full question in there.
Old Jan 14, 2009 | 05:32 AM
hondaownr's Avatar
actually the hfs do have those mounting bolts for the rear sway..
88's are the only ones that dont..
Old Jan 14, 2009 | 01:36 PM
I just want to get new lower control arms for my HF (90-91) because they are worn out. I am not in need of a rear sway bar. I can get Blox or whatever is on ebay, right? They will fit? What's recommended? (Can I have a 'sporty' recommendation, and a Daily Driver rec too?)
Old Jan 14, 2009 | 02:19 PM
EFRue57's Avatar
Don't take this the wrong way but I wasn't posting that for you but for the OP.
i have owned two 89's and they both didn't have it. maybe it's just the 90-91's that do have them.
Old Jan 16, 2009 | 04:26 AM
EFRue57,
I know you were posting that for the OP, no offense taken!
Am I gtg then with 'any' lower control arms for CRX's then, for my late year'd HFs?
Old Jan 16, 2009 | 05:30 AM
DTA-Zombie's Avatar
I know I have read a few bad reviews for the blox simply due to bushings...but yes any of them should fit...
Old Jan 16, 2009 | 08:44 AM
hondaownr's Avatar
blox is garbage..i have them on my hf right now..
bushings go bad in 2 months..
but for $70.00 you cant beat it..
you can try the skunk 2's i heard they last pretty long
hucoreyCRX
Mar 22, 2007 04:50 AM
GI8U2racing
16
Nov 30, 2006 03:31 PM
89_ZC_crx
24
Feb 13, 2006 01:56 PM
HT Chaplain
Jan 6, 2006 11:20 AM
