dpfi to mpfi question
Old Aug 10, 2008 | 02:26 PM
Excel91CiViCsi's Avatar
Default dpfi to mpfi question
hey guys, ive been reading around and looking for some info but would like to clarify some things. im getting a 91 std hatch, and wanna go z6 swap. if i buy just the motor harness from rywire that is plug and play to go dual point to obd1 vtec will that run straight to the ecu and make it so that i dont have to change anything other than get a ecu jumper harness?
second, could i just get a 88-91 si dash and motor harness to make it multi which would be more work but, save me some cash.
and third, would a 90-91 integra harness work for inside the car and for the motor if i got them both? and i read if i go mini me which would be obd1 i dont need a resister box correct?
thanks
Old Aug 10, 2008 | 02:33 PM
Spleen's Avatar
Default Re: dpfi to mpfi question (Excel91CiViCsi)
I cant answer your question about the integra harness or resistor box, but I will assure you its cheaper and easier to add the wires to your stock harness. It is more confusing, but I only spent $15 for the wire at Auto Zone (bought a couple different colors) and $8 for a large pack full of crimp connectors. Way cheaper than buying the harness and a lot less work to just run the wires than getting a whole harness. There's a hole in the firewall right above the ECU, thats where I ran my wires.
Old Aug 10, 2008 | 06:15 PM
Default Re: dpfi to mpfi question (Spleen)
thanks man i appreciate it.
Old Aug 10, 2008 | 06:23 PM
mit7059's Avatar
If you do a mini-me you will need to add the resistor box and switch it to MPFI, you can keep it OBD0 by adding either a RPM activated switch or a piggyback to the ECU, you can read all about it in the FAQ at the top of the EF forum.
Old Aug 11, 2008 | 02:35 PM
bumppp
Old Aug 11, 2008 | 04:49 PM
SlipGear's Avatar
Solder the connetions Cleaner and Better
hatcht9x
12
Sep 7, 2025 10:49 PM
totoshatch
Jul 20, 2007 01:46 PM
yz125rider21
Feb 5, 2007 12:13 PM
DOHCintegra91
Sep 24, 2006 08:29 AM
dizzyek
Feb 9, 2006 01:50 PM
