Manual transaxle fluid change
So i removed the drain plug from my DA and drained all the oil out. when i went to remove the filler plug located on top of it, it was impossible...i basically stripped the bolt without it budging... sooo i went ahead and removed the speedo cable from the tranny and attempted to fill it through a hose-bottle-funnel contraption i cooked up and all the fluid just leaks under the car...so im kinda stuck...heres a picture of where im trying to pour.
http://i530.photobucket.com/al...9.jpg
please help!
thanks
please help!
thanks
I requested a short story for a title.
do you have a hose? or are you just tryin to pour and hope you hit?
you should not have a problem if you can get a good size hose on that and run it up to a funnel
Yea i was using a 1/4" hose then ran it up to a funnel basically and it went down but just spilled everywhere...do i have to remove anything else? like a gear or anything?
hmmm im not sure, when i changed mine the fill hole plug came right out, but it should not be that tight. see if you can get some lockin vice grips around it and get it loose. i dont know if there is anthing else to remove for the way your doin it now tho
or maybe tiry fillin it from the alxe amxle mount but i dont know if that iwll work
ya i tried the vise grips too...and a pipe around a wrench, and a ratchet but no luck lol this is one of those stupid things that shouldnt happen...
so there isnt anything else to remove outta the tranny except the speedo cable right? and i dont have to remove any gear just the cable right?
piggydog
Mar 12, 2007 04:05 PM
