B16 ef question?
will aftermarket headers for a 99-00 civic si b16 fit on a b16 91 civic ef, and will the stock exhaust boelt on proprly, or ill have to get a whole aftermarket exhaust system with the si headers?
all b series parts(sept vtec cams and non-vtec cams) are interchangable so they will bolt right in the only difference is the space but im 99.9% positive they will fit, and also the si b16 is pretty much the same motor just runs a differient computer and some new sensers so you might need to look into new o2 sensers but i could be mistaken
It will bolt up. I have a DCSports 99-00 Si header with the stock CRX cat and Skunk2 catback, bolted up just fine...
If you are still obd-0, you would need to get 2 02 bungs welded in for your sensors.
BTW, 94-97 DelSol VTEC and 99-00 Civic SI header have the same part#.
Edit: A 4-1 header won't clear the stock crossmember...
Most any aftermarket header will be an issue with figment on a 4th gen.
notching the X member is pretty much a given for any long tube setup, or an aftermarket X member.
