da clutch cable help. ASAP
Old Aug 9, 2008 | 03:11 PM
lsvtecpower's Avatar
Default da clutch cable help. ASAP
i have a da with a fully built ls vtec. i heard the clutch cable snap? i pulled into the shop just fine, go to leave no clutch? pedal was very rought, and went to go into reverse and it grinded real bad so i shut it off and go check the clutch cable and it was really loose.( up till now its been perfect with no adjustment on sleeve) so i tightened up till it got tight agian then try reverse agian same thing so checked cable agian and its loose again(and not tripped on the sleev same spot as it juts was) so i tightened it agian and no grinds just hard to get into gear and the engagement is way down. and very jumpy when taking off. im pretty sure its the clutch cable so i will just replace it to be safe but just wondering if this has happened to anyone else and what else it could be? and to remove the cable from clutch dont you jut pull the groment and just unhook from clutch pedal? thanks for the help in advance
bmxtrev
Transmission & Drivetrain
May 20, 2011 08:10 PM
Beeracer930
Apr 25, 2010 09:51 PM
SL0-hatch
Apr 21, 2008 12:28 PM
InJ3cted
May 24, 2005 02:16 PM
