1992 Honda Prelude wont start!!
Old Aug 9, 2008 | 12:19 PM
Yuyodrift91's Avatar
Default 1992 Honda Prelude wont start!!
there is a problem with my 1992 Honda Prelude S. some how at times it wont start. im thinking it might be due to the starter. i changed the starter coil and replaced it but it still didnt start. the engine is fine nothing wrong. and when it wont start the D4 light flashes. this only happens when i have low gas...could it be the ignition distributor??
Modified by Yuyodrift91 at 1:47 PM 8/9/2008
Old Aug 9, 2008 | 01:03 PM
zsudz922's Avatar
Default Re: 1992 Honda Prelude wont start!! (Yuyodrift91)
first make sure all your spark plugs are good.check and make sure you are getting spark to each of the cylinders/spark plugs. if you are not, disconnect the coil wire goin to the distributor and make sure you have spark coming from the coil. if you have spark at the coil but not at any of the cylinders then you may need a new distributor. if you do get spark at some, but not all of the cylinders, then you need new park plugs wires.
whens the last time you installed new spark plugs, wires, distributor cap and rotor?
Old Aug 9, 2008 | 01:17 PM
Default Re: 1992 Honda Prelude wont start!! (zsudz922)
well most of that i changed about a year ago. ill try what you told me and let you know if the problem persists...
Old Aug 9, 2008 | 01:24 PM
socialistic's Avatar
If it's not a spark issue...
Could be the main relay...search around for how to check and fix the solder joints on it. Easy to do and usually gets rid of start up issues.
Old Aug 9, 2008 | 03:29 PM
PreluWD's Avatar
Default Re: (socialistic)
It's most likely the main relay issue. Nearly every 4th gen prelude succumbs to that problem at some point in its ridiculously long life.
The mechanic at the honda dealership that services my car says that a fairly common problem that also occurs in the 4th generation is an absence fuel pressure. Have them check that out too.
teamTakeo
Aug 20, 2023 07:58 PM
candyteggy
Nov 10, 2006 02:32 PM
j-rogers01
Jan 26, 2006 11:05 AM
widecoupe
May 12, 2002 11:26 AM
96whitels
Aug 19, 2001 02:06 AM
