what ecu can i use for h23 turbo
Old Aug 9, 2008 | 12:04 PM
jprelude92's Avatar
Default what ecu can i use for h23 turbo
i wanna buy an ecu for my h23 turbo but i dont know what ecu to buy,i have been doing some research and some people say to use p06,p28,p74but this ecu's can't control the AIB and knock sensor the only ecu that can is the p72.
is there anyone that has prelude h23 turbo that can point me to the right direction with what ecu i should use, i want to be able to use the AIB,knock sensor,read codes be able to use my ABS ETC i don't want to see the check eng light on. thanks.
Old Aug 9, 2008 | 12:19 PM
95greenlude's Avatar
Default Re: what ecu can i use for h23 turbo (jprelude92)
https://honda-tech.com/zerothread?id=567799
Old Aug 9, 2008 | 01:21 PM
socialistic's Avatar
A chipped p72 is really the only way to go if you want to keep iab/knock, just make sure you know a good tuner.
It is possible to add iab to a p28(xenocron add-iab chip kit = $5), but I'm not exactly sure how that works...you'd have to ask someone at xenocron or someone on the pgmfi forums. There is currently no way that I know of to add knock to a p28.
I really don't see a point in keeping knock, personally. I am also deleting my iab & egr before my car goes in for a tune, and knock will obviously not work any longer since I'm running a p28 equivalent ecu.
Old Aug 9, 2008 | 01:39 PM
mongtite's Avatar
Default Re: (socialistic)
pricewise, P28 is cheaper and hondata s300 if you have the money.
Prelude ECu are not really tunable. p72 is a little more but if you're turboing it. P28 is Darn Good.
Old Aug 10, 2008 | 09:52 AM
jprelude92's Avatar
Default Re: (mongtite)
how do you get rid off the aib? and if you do are'nt you gonna run into any problems with loss of hp or idle? i have heard people saying that,don't know if is true or not.
not-a-stang
Mar 4, 2009 11:33 PM
JSpekBB4
Jan 18, 2006 04:48 PM
hOndafienD 04
Aug 30, 2004 07:58 PM
slowe6
Apr 2, 2004 06:12 PM
teamlegacy
May 15, 2003 10:18 AM
