Who maps P72 to H22
(the following is to my understanding, and if I'm wrong please correct me)
It would likely be safe to use the h22 map if your using the h22 vtec injectors (for the time being) in your h23vtec setup (temporarily)
So you would probably start with a p13 program and have it burned to your p72 (by what ever means you wish to use either a burn1 or ostrich or hondata setup) and this should only be used in order for you to get to the tuner. Do not drive on this basemap for long.
As far as I know though without balancing your motor, you probably shouldn't be reving the motor past 6500 as you would with a typical h22 vtec motor.
Good luck and get it tuned asap (no excuses)!
It sounds like it's gonna take me a while specially cuz I live in El Paso, and here nobody knows how to do ****. I'm getting the P72 next week, hopefully I didn't make a mistake, and yes, I"ll get the bottom end balanced, what makes it hard is finding places that know what the hell they're doing, I always rely on forums for advice instead of shops. Thanks!
Anyways, who do I contact to get the p13 program for the p72?
Modified by meanshyguy at 10:05 AM 8/10/2008
swrdply400mrelay
Jul 2, 2003 09:15 PM
