Olympic Suicide Sale - obd1 shell - turbo kit - d16a6 cammed
Old Aug 9, 2008 | 07:12 AM
digitalcongo's Avatar
Default Olympic Suicide Sale - obd1 shell - turbo kit - d16a6 cammed
COLUMBUS OHIO
In light of the look on George Bush's face when Iraq entered for the Parade Of Nations...
I've decided the world needs to change...in a big way...
I've heard big change starts with yourself.
So I"m selling everything in hopes of some grand life realizations.
My prices are about as firm as the barrell in my mouth...please dont push me
<FONT SIZE="6">PICTURES UPLOADED</FONT>
If i missed something in the first wave of pics...just ask.
'94 LX 4 Door Shell - $650
Just completed auto/manual conversion. (includes conv. mount)
Its charcoal grey with tint.
needs the manual brake pedal put in (but would work as is)
very clean interior
d16a6 longblock with a6 web cam - $380
160k on assembly.
new valve,cam,main,pan,head seals
new oil & water pump
new oem timing belt, tensioner & spring
completely cleaned and painted silver.
choice of a6 or z6 intake complete (z6 mounted)
b7 obd1 distributor
a6 reman alt w/ new belt (a6 crank pulley)
zero miles since rebuild
needs valves lashed and a transmission
d.series turbo kit - $best offer$
skyline rb20 turbo - good for about 250hp @ 1bar
6.bolt partial 3" downpipe
piping kit w/ greddy flange
fmic
ebay greddy bov
ebay manifold w/ xtra support welds
ebay wastegate (dig in photobucket for pics)
oil feedline with 3.way splitter for stock oil pressure
synapse missing link map adapter (not pictured)
oil pressure gauge w/ sender
turbopac boost gauge (10psi)
chipped p06 - $100 as it sits - $130 w/ vtec
ready for any basemap including gsr/h22 (iab,ectune features)
i can also add vtec, have everything to do so.
this was an auto ecu converted to manual - remnants make iab,ectune,neptune worthy 12v control...etc
65" mitsubishi projection television - $Any offer$
needs new IC's soldered in
common problem for this model - also a fairly easy fix.
IC's are about $36 shipped on ebay
Also some artic silver to mount/seal to the heatsinks would be recommended.
two custom air water intercoolers ($100 each)
designed for v8's
these would make awesome custom projects for warm/cold air switch for gas mileage and performance on the go.
obd2 jdm d15b block bare - $80
this is my jdm 3.stage block
this would make a great block to build an obd2 motor if needed.
pretty rare
comes with oil pump w/ ckf (crank position sensor)
also has the aluminum oil pan
i may be persuaded to include the pistons/rods if interested.
water pump also there w/ t-stat housing...etc
92-95 ex tranny with blown diff - $80
perfect for someone going LSD
4.25 final drive and ex gearing
jdm itr front end conversion for 92-00 civics - $1500
includes jdm itr carbon fiber hood
fiberglass conversion fenders new
brand new oem jdm itr black housing non-hid headlights
brand new oem jdm itr core support
new fiberglass front bumper & lip
integra hood latch used
integra full radiator with fans used
requires spot-weld drill bit - removal/install of core supports
everything else is bolt-on
this all could be done in the driveway
83-07 computer manuals all import & domestic - $offers$
includes all TSB's and all the pictures you people see me use
you can see some screenshots here
this is about 50gb - so you must provide the dvd's to burn
it can much less data and money if you only want honda...etc
b7 block complete - make offer
needs broken t-stat housing bolt replaced
b7 longblock - make offer
pretty complete needs new headgasket
obd1 non-vtec wiring harness - $50
complete uncut
z6/z1 vtec dizzy - $50
td42u
oem d16a6 cam w/ gear
volvo 750T oil cooler w/ lines
slim fan
92-00 dual core civic radiator (auto or manual)
ITR rear sway bar - Brand New w/ bushings
Suspension Techniques 88-00 civic springs
Integra 1" brake master (have line for civic conversion)
plenty more...look in photobucket possibly
GET THESE PARTS BEFORE I'M DEAD !!!
i have lots more
if you know of something i have that you want make an offer
i'm sure i i will post more after i get a trip to the garage with the camera.
SO LOOK BELOW FOR MORE
lowballers will be shot before i shoot myself
private messaging is always preferred
please use it for any kind of communication
this helps threads remain uncluttered
EVERYTHING IS IN COLUMBUS OHIO
Old Aug 9, 2008 | 08:08 AM
Fibercation's Avatar
Good seller
Old Aug 11, 2008 | 02:01 PM
Default Re: (Fibercation)
bump
Frost7177
Jun 27, 2007 06:26 PM
Ahknodd
Mar 20, 2007 01:27 PM
funkfnamna
Oct 4, 2005 01:17 PM
crx2ner
Jun 30, 2005 07:30 PM
AgentJam
Nov 30, 2004 12:58 PM
