Vacuum tubes
I need some help with vacuum lines. The Haynes manual is relatively worthless for this. At the back of the engine bay on the firewall should be a small flange with two pipes on it. Four vacuum tubes are attached to the pipes, and go to different areas in the engine bay. I need to know which tubes go where, I'm missing two and I have a feeling this is the cause for my wacked out idle and cruise control. Pictures would be the best way to show me, if at all possible.
Here's a picture of the said flange:
the top one goes to the evap canister under your cruise control diaphram.
the bottom one goes under the stock intake into a box near the air filter.
these both come from the intake manifold.
Heh, I think I'd need pics, especially since one of the tubes leads to an intake that doesn't exist anymore...
[Modified by martaigne, 2:42 AM 7/23/2002]
But there's four tubes?
THE BOTTOM LINE goes through a series of check valves and runs along the intake and ends up plugging into a vacuum canister under your stock intake. I looked at a stock accord for this.
CSHornet60
Mar 9, 2007 06:00 PM
drumminforev
Mar 11, 2006 12:42 PM
