would skunk2 pro 1 cams work with 1mm oversized valves?
recently i bought some pro2 cams and was going to put them into my car, but then i found out that its not possible due to my oversized valves. I sold the pro2's so now, im planning to buy some pro1 cams and I have 1mm oversized valves. would they work? i know i have to degree the cams and everythng. its going into my c5, right now i have stock pistons in them, i might go with 12.5 compression pistons soon.
thanks in advance.
thanks in advance.
The only way to know is to check your Valve to Valve clearance, not hard to do. I had .055" V2V clearance at 0/0 gears wtih stock valves.
When I degreed my Pro1's the EX ended up +3.5 degrees more than the IN, which gave me more V2V clearance than 0/0 cam gear setting. hope this helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rh76pogi »</TD></TR><TR><TD CLASS="quote">The only way to know is to check your Valve to Valve clearance, not hard to do. I had .055" V2V clearance at 0/0 gears wtih stock valves.
why do some people degree their intake cams in negative degress? which one is better? degreeing the intake negative or the ex positive?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BABY NSX »</TD></TR><TR><TD CLASS="quote">My B18C5 was built with 1mm oversized intake valves and pro-1 cams. Valves were from Fearra.</TD></TR></TABLE>
Yeah, I got 1mm oversized on both exhaust and intake. And my whole valve train is fearra. From seats up to retainer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rh76pogi »</TD></TR><TR><TD CLASS="quote">When I degreed my Pro1's the EX ended up +3.5 degrees more than the IN, which gave me more V2V clearance than 0/0 cam gear setting. hope this helps
While I'm in China and can't actualy check my settings. Mine were degreed to Skunk2 specs and I seem to remember my EX being about 3.5deg more advanced then the IN.
My cams degreed In +3, Ex +4 using the peak method and Skunk2 specs. I had 0.055" V2V clearance with this setting. Head had a fresh valve job and running standard Skunk2 valves.
https://honda-tech.com/zerothread?id=2308910
ohsnapzafingcu
May 31, 2007 06:58 PM
Boner_Ben
25
Jan 19, 2006 08:05 AM
matata55
Dec 23, 2004 09:54 PM
