quick exhaust fitment question
Old Aug 9, 2008 | 12:46 AM
dfer2190's Avatar
Default quick exhaust fitment question
will a greddy evo 2 catback off of an integra gsr fit an ls without modification?
Old Aug 9, 2008 | 04:47 AM
ac_attak's Avatar
Default Re: quick exhaust fitment question (dfer2190)
What year is the gsr? If its an 00-01 gsr then yes it will fit.
If its a 94-99 gsr then the piping will need to be shortened.
Old Aug 9, 2008 | 06:16 AM
JdmTypeRdc2's Avatar
Default Re: quick exhaust fitment question (ac_attak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ac_attak &raquo;</TD></TR><TR><TD CLASS="quote">What year is the gsr? If its an 00-01 gsr then yes it will fit.
If its a 94-99 gsr then the piping will need to be shortened.</TD></TR></TABLE>
^^yup what he said
all 94-01 integra exhausts are interchangeable...except for the 94-99 gsr, which is 2 inches shorter at the cat, and 2 inches shorter at the b pipe, so you will need to shorten the exhaust 4 inches in order for it to fit on that year gsr (unless you have an aftermarket header)
Old Aug 9, 2008 | 09:51 AM
dfer2190's Avatar
Default Re: quick exhaust fitment question (JdmTypeRdc2)
well it's off a 95 gsr going into a 96 ls
Old Aug 9, 2008 | 10:00 AM
Adambomb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfer2190 &raquo;</TD></TR><TR><TD CLASS="quote">well it's off a 95 gsr going into a 96 ls</TD></TR></TABLE>
Sounds me like you'd need to lenghten it then.
Old Aug 9, 2008 | 10:21 AM
ac_attak's Avatar
Default Re: quick exhaust fitment question (Adambomb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adambomb &raquo;</TD></TR><TR><TD CLASS="quote">
Sounds me like you'd need to lenghten it then. </TD></TR></TABLE>
No its coming off a 95 gsr and going on a 96 ls, so the b pipe needs to be shortened approx. 4.5"
Old Aug 10, 2008 | 09:56 PM
dfer2190's Avatar
ok new question...what about an exhaust off a type-r onto a 96 ls...any fitment issues?
Old Aug 11, 2008 | 05:44 AM
Little_Nolan's Avatar
Default Re: (dfer2190)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfer2190 &raquo;</TD></TR><TR><TD CLASS="quote">ok new question...what about an exhaust off a type-r onto a 96 ls...any fitment issues?</TD></TR></TABLE>
^That should fit just fine.
Old Aug 12, 2008 | 05:14 AM
No its coming off a 95 gsr and going on a 96 ls, so the b pipe needs to be shortened approx. 4.5" </TD></TR></TABLE>
wrong...its coming from a 95 gsr which means the b pipe is 2 inches shorter and the cat is 2 inches shorter than the 96 LS. Soo...you would need to extend the smaller GSR b pipe to fit the LS.
Old Aug 12, 2008 | 05:19 AM
All integra piping is the same from 94-01, no matter what model, except the 94-99 GSR, so a type R exhaust should have no problem being a direct fit, however, the ITR b pipe is slightly larger in diameter, so if you are going with that option, i would suggest getting a slightly bigger hi flow cat.
Old Aug 12, 2008 | 07:16 AM
ac_attak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmTypeRdc2 &raquo;</TD></TR><TR><TD CLASS="quote">
wrong...its coming from a 95 gsr which means the b pipe is 2 inches shorter and the cat is 2 inches shorter than the 96 LS. Soo...you would need to extend the smaller GSR b pipe to fit the LS.</TD></TR></TABLE>
No, you are wrong. The exhaust manifold is about 2" shorter, and the cat is about 2" shorter. Lay a 95 gsr b pipe and a 96 ls b pipe side by side. The gsr b pipe is 4.5" longer. He needs to shorten it. If you still think i am wrong, research it and get back to me.,.
http://www.team-integra.net/fo...Topic
kennybintegra
Mar 28, 2007 05:38 PM
Jay Blazed
Aug 26, 2006 01:05 PM
WillyD6869
Jul 3, 2005 10:05 PM
eymnewdc4
Dec 2, 2004 11:06 AM
StolenTeg
Jun 28, 2004 07:43 PM
