ok i did some looking around, i think i may have answered my own question.
i found this pic
thats an EF with the ASR brace. ok so it does bolt up. that means the distance between the LCAs is the same on the DC and the EF.
and because i plan on using Blox LCAs for a DC teg, that means its going to be the same distance from endlink-to-endlink, and the DC rear swaybar should bolt right up, right?
I think I remember seeing that thread with the ASR sub frame brace on that crx but it doesn't just "bolt on". I think the guy just used a integra brace and drilled new bolt hole in the sub frame for the brace, probably not the best way to do that. And I think ASR has a sway bar kit but not a sub frame brace for the EF's (but could be wrong).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 »</TD></TR><TR><TD CLASS="quote">I think I remember seeing that thread with the ASR sub frame brace on that crx but it doesn't just "bolt on". I think the guy just used a integra brace and drilled new bolt hole in the sub frame for the brace, probably not the best way to do that. And I think ASR has a sway bar kit but not a sub frame brace for the EF's (but could be wrong).</TD></TR></TABLE>
Yeah the ASR EF kit uses brackets that attach to the tow hook brackets, but it doesn't have the subframe bar. It also uses a highly desireable chromo straight sway bar. No biggie about the subframe bar though, as there are 100s of those available out there. easy peasy.
i dont think youre correct. the two bolts he is using in that picture, are clearly the same bolts that hold the LCAs to the subframe, just as it is intended to be used on an EG/DC
its not really possible to drill your own holes in the subframe for those two specific holes in the brace, because behind that is where the LCAs meet the subframe. if it was even a millimeter off, and u needed to drill a hole, you would be drilling through the LCA's bushing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 civic ef »</TD></TR><TR><TD CLASS="quote">i have blox LCA and they are fine but heard that when they first carme out the blox lca were bad because of the bushing but the new ones are fine</TD></TR></TABLE>
Post pics of the "new" ones if you have them! I bought mine less than 2 months ago, and the bushings are like warm jello...and I havn't even used them yet. I pressed the blox bushings out and replaced them with full poly I had left over from a complete master set. I'm going to have to run a simple washer on either side of the bushings, but it'll be much much stiffer.
The blox bushings are WAY softer than even oem replacements.
the bad thng about running teg lca's is you get -camber from it but they bolt right up to the ef, eg, and ek platforms. And i don't uderstand how the kit in the last pic works. And why would you not want to run the sway bar if you have the lca's with holes for it? It just makes no sense to me
Re: usdm-ITR rear sway-bar on an EF? (turboblack2door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboblack2door »</TD></TR><TR><TD CLASS="quote"> And i don't uderstand how the kit in the last pic works</TD></TR></TABLE>
What exactly don't you understand?
The ASR kit has brackets that attach to the factory tow hook mounts. It utilizes a straight chromoly bar for a sway bar instead of a typical bent peice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboblack2door »</TD></TR><TR><TD CLASS="quote">the bad thng about running teg lca's is you get -camber from it but they bolt right up to the ef, eg, and ek platforms.
Modified by turboblack2door at 4:33 PM 8/9/2008</TD></TR></TABLE>
yeh all u have to do is use DC teg upper control arms as well. both of them are 1/16" longer than EF arms
1/16" isnt going to cause major camber issue, but im sure the difference is visable
it confirms that the ASR brace does fit fine on an EF, the only thing is that you would use a DC/EG brace, so its not going to have provisioning for an EF swaybar. so you use a DC swaybar... which im planning on anyways..
Modified an Integra rear sway bar to fit my EF. Pretty much now an Integra in the rear with the option of upgrading to the thickest factory bar. Mind the welds, I'm not the best. Just figured I'd post for anyone interested.
