Changed fuel filter now no idle
Old Aug 8, 2008 | 06:45 PM
wesleywhite989's Avatar
Default Changed fuel filter now no idle
I changed my fuel filter and cleaned my iacv changed the hoses that run from the fuel canister to the im (intake manifold) and now my car wont idle at all even if i put it in neutral it will die out can some body please help me out doesnt matter if car is cold or hott it wont idle... its a 90 crx with a b18a and b16 head... vtec is not wired up.. umm was working before these things were changed...
please help me.......
Old Aug 8, 2008 | 07:09 PM
pandarex's Avatar
Default Re: Changed fuel filter now no idle (wesleywhite989)
some sort of vacuum leak. most likely a problem with your iacv
Old Aug 8, 2008 | 07:12 PM
Default Re: Changed fuel filter now no idle (pandarex)
so now my iacv needs to be replaced??
Old Aug 8, 2008 | 08:20 PM
khooper's Avatar
Make sure it is getting the proper air flow. Is the intake duct sealed. The fuel pump good. My dad had a problem with his catalyst converter not getting the proper air and now it wont go over 25.
_____________________________
Check out how I became a Car Fanatic
Old Aug 8, 2008 | 08:28 PM
Default Re: Changed fuel filter now no idle (khooper)
i dont even have a cat... well i have one but its not on the car when i bought it came with a straight pipe thats bolted on lol exhaust is horrible needs work but did run fine before i cleaned the iacv i just followed the instructions in faq and now no idle
Old Aug 8, 2008 | 09:21 PM
pandarex's Avatar
try this
https://honda-tech.com/zerothread?id=2153910
Old Aug 8, 2008 | 09:44 PM
grog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wesleywhite989 &raquo;</TD></TR><TR><TD CLASS="quote">so now my iacv needs to be replaced??</TD></TR></TABLE>
its possible, but first make sure everything is hooked up right. is the IACV plugged in?
Old Aug 8, 2008 | 09:53 PM
Default Re: Changed fuel filter now no idle (grog)
yeah plugged everything back in when i start it it will idle then as soon as i give it a lil bit of gas it will rev up then die out wont correct it self to hold an idle
Old Aug 8, 2008 | 09:55 PM
the screen on the iacv was black really dirty took quite a bit of brake cleaner to clean it... i let it sit for about hr or two then put it back in and started it up ran fine but as soon as i gave it a lil bit of gas just died out
Old Aug 8, 2008 | 10:48 PM
949's Avatar
949
mine does the same, did you ever fix it?
when i gas it alittle the engine will just stall out. if not it will idle ok.
Old Aug 9, 2008 | 11:41 AM
Default Re: (949)
well runs fine today... kinda bogs out and hesitates when i let of the gas but it will recover and regain idle i know my air to fuel ratio must be jacked...
Old Aug 9, 2008 | 05:12 PM
Default Re: (wesleywhite989)
ill take that back as soon as it warms up to normal running temp no idle i think its my iacv is there anyway i can service it instead of replacing it?
Old Aug 9, 2008 | 05:50 PM
grog's Avatar
I doubt it. I think the seals are what go bad on those, and using harsh cleaners might cause some damage to the seals, but its always worth a try.
If it were me I would try cleaning it out one more time. I found that pressure really helps when cleaning the IACV either from the aerosol or copressed air
Old Aug 9, 2008 | 06:15 PM
Default Re: (grog)
bump ill try cleaning it again and hopefully that will fix things dont really feel like buying a brand new one there pretty pricey
Old Aug 10, 2008 | 11:24 AM
cleaned it again an blew air through it let it sit out all night then put it on and fired it up will idle but as soon as u give it gas it wont correct itself and hold an idle it will just die.... so where do i go from here what are my options ??
Old Aug 10, 2008 | 03:06 PM
tico's Avatar
im going out on limb here but check ur ecu for codes. ysterday i was coming home on the free way when all of a sudden my car started bogging down and almost die when i gave it gas. well after driving the CEL came on so i barely made it home and it read code 7. TPS. so i unplugge it blew out any possibldirt in the coonections made sure all the wiring was good. plugged it back in reset the ecu and ran perfect
Old Aug 10, 2008 | 04:55 PM
Default Re: (tico)
yeah i had the same code today... actually i did the same thing and still was bogging down bad so i just adjust the idle and now its up and down but at least its not dying out gotta wait till pay day and im gonna get a new tps and iacv gotta unless my friend will let me use the parts and pay em later
Old Aug 11, 2008 | 06:23 AM
grog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wesleywhite989 &raquo;</TD></TR><TR><TD CLASS="quote"> i just adjust the idle and now its up and down </TD></TR></TABLE>
that could also be the FITV, when they get out of adjustment they can cause the idle to bounce around.
Look through the faqs for the write-up on adjusting it.
Modified by grog at 7:30 AM 8/11/2008
Old Aug 11, 2008 | 05:38 PM
949's Avatar
949
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wesleywhite989 &raquo;</TD></TR><TR><TD CLASS="quote">cleaned it again an blew air through it let it sit out all night then put it on and fired it up will idle but as soon as u give it gas it wont correct itself and hold an idle it will just die.... so where do i go from here what are my options ??</TD></TR></TABLE>
wow you kinda described what is happening to me.
i did try to clean out the aicv and the fitv but the idle just stalls out.
no bouncing anymore after i replaced the tps sensor.
i also tested out my iacv. at this point i just ordered a new fitv and a aicv. i dont think that even with the testing it will work correct. because the symptoms occur after the car is very warm.
during the cold the symptoms wont show. when i tested the aicv it wasnt warm. so im thinking i should just replace it.
Modified by 949 at 6:46 PM 8/11/2008
shreddinryguy
Jun 13, 2006 11:05 PM
machine4321
May 26, 2004 04:10 PM
Cheap Bastard
Sep 3, 2002 10:08 AM
vtechatch
Aug 10, 2002 06:54 AM
