Changing the a/c belt question (I searched)
Old Aug 8, 2008 | 05:02 PM
ShinyNewPenny's Avatar
Default Changing the a/c belt question (I searched)
I have a '93 Civic SI. I know I have to remove 2 bolts to lower the mount/bracket that is in the way of putting on the belt. All the threads I could find people just said remove the two bolts and put the belt on, do I need to support the engine when I take the bolts out or anything? Should I put the car on jack stands when I do this? I'm just trying to clarify some stuff before I change the belt.
Also, there hasn't been a belt on the compressor in at least a year and a half, not sure how long the previous owner didn't have one on. The pulleys look a little rusty, not much, just a little. Would I be alright to just pop the belt on and go from there or would I need to do anything else. Do you guys think the coolant would still be good too?
Old Aug 8, 2008 | 06:05 PM
rivaladore's Avatar
Default Re: Changing the a/c belt question (ShinyNewPenny)
Not only do you have to loosen the two belts for the pulley, you also have to take off the AC braket/mount. Here is a link for doing a timing belt change but it shows you how to take off the power steering/alternator and AC belt.
https://honda-tech.com/zerothread?id=649277
Old Aug 8, 2008 | 06:45 PM
alphalanos's Avatar
Default Re: Changing the a/c belt question (rivaladore)
I used a jack to support the motor. You have to loosen the P/s adjustment bolt, remove the belt. Then Loosen the A/c belt tensioner. remove the bolts for the lower U mount then let the motor down just a little so you can slide a belt through. I had a really hard time getting the A/c belt on you might need a screw driver to help pry it on. Then just tighten the tensioner until you can puch the belt about a half inch in the middle with your finger. bolt the U mount back up and reinstall P/s belt and retighten the same way.
SoEvoL
Jun 6, 2006 10:07 PM
Shaun
Feb 22, 2006 10:24 AM
95TEG
Aug 27, 2005 08:55 PM
confucius
May 18, 2005 11:42 AM
auto-gs-king
Aug 19, 2002 07:57 PM
