OEM JDM GSR/ITR LSD + 4.4 ring gear
Old Aug 8, 2008 | 03:39 PM
red civic standard's Avatar
Default OEM JDM GSR/ITR LSD + 4.4 ring gear
This differential/ring gear came out of a factory equipped LSD JDM GSR transmission.
The guy I bought it from said that he was running it in his cable b16 trans. I am not sure what trans.
I test fit the diff/ring gear in a USDM hydro GSR trans. The ring gear has a different bolt pattern than the USDM GSR/ITR 4.4, but the ring gear is identical functionally.
You will have to grind away part of the GSR or ITR case to get the differential to fit. This is very easy to do. Directions are here:
Looking for $300 shipped. I have many vouches here and on ef-honda.com
Old Aug 10, 2008 | 08:22 AM
Default Re: OEM JDM GSR/ITR LSD + 4.4 ring gear (red civic standard)
up
B18C5-EH2
Transmission & Drivetrain
May 8, 2017 06:55 PM
efhatch.gsr
Jan 27, 2012 12:51 PM
fourdoorturbo
Apr 30, 2007 02:16 PM
shamoo
Mar 15, 2002 06:33 PM
