Skunk2 manifold issue
Old Aug 8, 2008 | 01:24 PM
autoxthis's Avatar
Default Skunk2 manifold issue
I've installed a pro series manifold on my b18c1 which is in a 91 crx. I swapped the stock throttle body with a type r and bought a type r throttle cable and throttle cable bracket. My issue is this, the throttle cable is too short! From the throttle cable bracket to the pedal assembly, it will not hook up without the throttle body opening up.
-Is anyone is running a similar setup?
-What did you do to solve this?
-What throttle cable should I use?
I think I may go to a junkyard and grab random throttle cables and see what works. Before I do this can anyone shed some light on the subject?
Old Aug 8, 2008 | 02:36 PM
redrim's Avatar
Default Re: Skunk2 manifold issue (autoxthis)
gsr
autoxthis
Aug 9, 2008 07:48 PM
autoxthis
11
Aug 9, 2008 11:52 AM
autoxthis
Aug 9, 2008 09:18 AM
krucial7integra
Jan 11, 2007 12:31 PM
