oil pressure sensor cracked stuck in block
Old Aug 8, 2008 | 11:07 AM
one-cam's Avatar
Default oil pressure sensor cracked stuck in block
got my motor built and when i was putting in my oil pressure sensor it broke. i want to get my motor in asap but ran into this problem. any help on getting this out will be helpful
a little preview
Old Aug 8, 2008 | 11:57 AM
blk92_d16's Avatar
Drill it out, tap the hole.
Vitara setup I see! What's the plan?
Old Aug 8, 2008 | 03:22 PM
one-cam's Avatar
Default Re: (blk92_d16)
Vitaras 75.05mm
Eagle Rods
ARP headstuds
Hondata s200
.. in a 90 dx converted from dpfi to mpfi and now being converted to obd1. y7 block, skunk2 z6 head.. mini-me
Gonna open a thread here shortly on the build
Old Aug 12, 2008 | 09:54 PM
nihad's Avatar
Default Re: (one-cam)
If you drill and tap you are gonna have to take the girdle off to get the shavings out. It will fall down in to it.
Old Aug 13, 2008 | 04:43 AM
cpl rampage's Avatar
Default Re: (nihad)
yeah, drilling and tapping would work, or u could always weld it ****, and then get a sandwich adapter, and run it off of there.
Old Aug 13, 2008 | 06:21 AM
Frozen E's Avatar
H-T White Ops
Default Re: (cpl rampage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cpl rampage &raquo;</TD></TR><TR><TD CLASS="quote">or u could always weld it shut, and then get a sandwich adapter, and run it off of there.</TD></TR></TABLE>
Least amount of asspain if you can do your own welding.
Old Aug 14, 2008 | 09:24 AM
one-cam's Avatar
Default Re: (nihad)
if you just drill a big enough hole to put on of these (easy outs) it should come right out
Old Aug 14, 2008 | 09:28 AM
slvrcvc93's Avatar
This happen to me once before but I had more to work with i got a flat head about the size of the hole tapped it in lightly then turned it like i was unscrewing the nut and it cam out with it. Left no metal shaving's in the motor
mmmbarp
11
Feb 19, 2012 04:00 PM
Charlie Moua
Mar 10, 2010 02:36 PM
GSROWNSU
Jul 15, 2007 08:57 PM
KooK
Nov 26, 2005 05:29 PM
Canuk_SiR
Aug 1, 2002 12:16 PM
