Coolant Temp Sensor
Standing in front of the car, look on the left side of the head. There is a coolant hose, the coolant temp sender, and then another sender unit. The coolant temp is the one in the middle, the single-"pin" unit that you can just pop off the connector to and unscrew. Warning, the sender might come apart during the unscrewing due to it being brass I believe...or some other britle metal.
holmesnmanny
Dec 19, 2011 10:40 PM
