Fog light question
Old Aug 8, 2008 | 06:15 AM
1sick4g63's Avatar
Default Fog light question
I noticed that most 92-00 civic's don't come with foglights, but they do sell them.
Are these cars pre-wired for factory fogs or do I need to do the wiring myself?
Old Aug 8, 2008 | 06:36 AM
slocivic99's Avatar
For sure the 99-00 civics are pre-wired, not sure about the rest though.
Old Aug 8, 2008 | 06:52 AM
94EG8's Avatar
Seagull Management
Default Re: Fog light question (1sick4g63)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sick4g63 &raquo;</TD></TR><TR><TD CLASS="quote">I noticed that most 92-00 civic's don't come with foglights, but they do sell them.
Are these cars pre-wired for factory fogs or do I need to do the wiring myself?</TD></TR></TABLE>
All '92 - '00 civic regardless of trim level have the single wire that runs from under the dash to behind the drivers headlight run, the plugs are taped to the loom with blue tape. All the rest of the wiring comes with the OEM foglight kit and is plug and play. I belive the aftermarket kits may require a little more wiring.
Old Aug 8, 2008 | 06:55 AM
1sick4g63's Avatar
So basically mount the fogs, plug them in, plug in the factory switch and a relay and I'm done.
Sweet. Thanks
Old Aug 8, 2008 | 07:15 AM
94EG8's Avatar
Seagull Management
Default Re: (1sick4g63)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sick4g63 &raquo;</TD></TR><TR><TD CLASS="quote">So basically mount the fogs, plug them in, plug in the factory switch and a relay and I'm done.
Sweet. Thanks</TD></TR></TABLE>
Something like that, they come with a harness that plugs into the combination switch on the steering column, you have to take the plastic covers off around the ignition switch if i remember correctly. Its all plug and play though. the honda '92 - '95 instructions are floating around online somewhere too.
Old Aug 8, 2008 | 08:34 AM
alphalanos's Avatar
I should be getting a set of the yellow square foglights later today so I can let you know how that goes if you want.
Old Aug 8, 2008 | 11:10 AM
NOFX's Avatar
H-T White Ops
They're pre-wired but did not come from the factory with foglights (no trim, not even the Si had them standard).
If you buy the OE kit you'll get a harness for the switch, the switch, the harness for the foglights, the foglights, a relay.. and I think that's it. I could be forgetting some things.
You'll have to cut the bumper too. Be careful how you cut it because certain parts might need to stay there in order to mount the lights correctly.
Droop408
Lighting
Feb 15, 2019 06:00 AM
ryc555
Oct 14, 2008 06:51 AM
jeeriko
14
Jan 28, 2008 04:45 PM
crxalltheway
Jul 15, 2007 07:54 AM
PhatboyNYC
Aug 15, 2003 12:20 PM
