F20B OIL PAN??
So F20B DOHC VTEC, hopefully a usdm oil pan can work for this engine, and id assume a h22 possibly would be the match. But would like a deffinate answer please. Also if it is a h22 pan, then which series engine, since obd1 and obd2 usdm have 2 different style pans. Thanks
That might be a tough one...I would try to contact member 'XES' as he is currently running a HIGH HP F20 hybrid and he is very knowledgeable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apex1972 »</TD></TR><TR><TD CLASS="quote">Weird, an H22 head fits that block. Why wouldn't the H22 oil pan fit. </TD></TR></TABLE>
Maybe it could fit if you use the matching oil pickup? Random thought. Possibly a 97+ pan and pickup to match?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsjon »</TD></TR><TR><TD CLASS="quote">Ill have to pull one out of th ebox and see how it looks(goodthing about working in parts). Appreciate the tip man : )</TD></TR></TABLE>
Welcome. Let me know if it looks the same. I never had a chance to test but that's what I was told
as far as i have seen with these two eyes, the f20b oil pan surface that mates to the block is perfectly flat. the h22 obd1 pan has raised areas on it where the rubber oil pan gasket siits. the f20b pan seals with hondabond. the obd2 h22 pan is flat as well but is aluminum and uses hondabond. the 98 and up f23 accords , as heikdiesel put it, use the same pan as the f20b using hondabond as sealant. so in saying if you were to use the obd1 h22 pan grab a rubber oil pan gasket. i dont see why you couldnt use the obd2 pan either. thats what ive seen with my eyes.
Modified by jr_deleon at 11:28 PM 8/29/2008
