charging system problem! low voltage! HELP ME!!!!
Old Aug 8, 2008 | 03:20 AM
Skunk U's Avatar
Default charging system problem! low voltage! HELP ME!!!!
first the car is a 91 crx si. heres the deal I can start the car and it stays running just fine. volt gauge says anywhere from 10.5-10.8 while running. battery light on dash is on as well. The car is on its second brand new alternator, all new grounds, new battery cables, new battery all obvious stuff replaced. Car has never died on me. I can turn on all the lights and the voltage doesn't change. I have also started the car with the alternator unplugged and the voltage stays the same even when its running. I am lost. please help
Old Aug 8, 2008 | 08:55 AM
jlicrx's Avatar
Default Re: charging system problem! low voltage! HELP ME!!!! (Skunk U)
sounds to me like your alternator wire is not connected to the main fuse box under the hood and you are just running off the battery - it is the wire at the bottom center of the picture of the engine harness below (ring connector) - connects into fuse box where it says alternator
Old Aug 8, 2008 | 09:12 AM
dlaub25's Avatar
Did you change the whole alternator out? The regulator and all?
Old Aug 8, 2008 | 11:08 AM
Skunk U's Avatar
I replaced the wire going from the alternator to fuse box already and it didn't change anything. And yes i changed the whole alternator out regulator and all.
Old Aug 8, 2008 | 12:12 PM
dlaub25's Avatar
Hows the alternator belt?
Also, this is just a stab in the dark but, I remember reading in my shop book that there is a circuit on CRXs that drops the output of the alternator under low load conditions.
Old Aug 8, 2008 | 08:33 PM
Skunk U's Avatar
The belt is good. I looked thru the haynes manual and read up on how test the system for shorts. I believe I found the short. It is in the stop/horn fuse circuit. This ever happen to anyone else. any tips?
Old Aug 9, 2008 | 07:36 PM
Skunk U's Avatar
need help bump!
Old Aug 9, 2008 | 08:53 PM
SOHCwarrior's Avatar
what volt gauge do you have? test with a volt meter at the alt and at the battery.
Old Aug 10, 2008 | 04:42 AM
Skunk U's Avatar
I get the volt reading thru my apexi turbo timer. also the battery light on my stock cluster is on.
Old Aug 11, 2008 | 02:21 AM
Skunk U's Avatar
help!
Old Aug 11, 2008 | 04:14 AM
JustAnotherRex's Avatar
Default Re: (Skunk U)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk U &raquo;</TD></TR><TR><TD CLASS="quote">I get the volt reading thru my apexi turbo timer. also the battery light on my stock cluster is on.</TD></TR></TABLE>
You got help. Test the voltage at the alt and battery.
Annihilator
Oct 14, 2009 04:55 PM
djrubio
Jul 18, 2009 07:41 PM
lmike6453
Jan 16, 2009 06:55 PM
aSDthing
Audio / Security / Video
Feb 9, 2008 04:00 PM
HybridHatchC1
Feb 8, 2005 04:26 AM
