help..weird smell when driving, can only be smelled by people behind me.
Old Aug 8, 2008 | 03:05 AM
imroadk1ll's Avatar
Default help..weird smell when driving, can only be smelled by people behind me.
ok i got myself a 95 gsr 2dr, mileage on it now is 160587 around there. the facts i know right now is that i know i need an oil change because the owner i bought it from said the last time he changed the oil was 157400 so im already 187 over. another thing is my boss told me i have an exhaust leak and i dont even know how to find out if i do have a leak (fyi he works at a body shop).
so tomorrow afternoon after i get off work i will buy a new oil filter to finally change my oil.
ok so tonight my friend was driving behind me and tells me that my car really stinks he doesnt know what it smells like but its like something is burning. so i tell him step on the gas while parked and i smelled nothing, so i think it only smells when im driving but i cant smell it while im in my car. can someone please help me on this one?
edit: changed my oil, the weird odd smell ended. now i started smelling burning rubber wen i started driving even my friend tailing me can smell it too.
edit: i smell somewhat burning rubber inside my car wen i started driving off after the oil change. my friend whose tailing me tells me he smells rotten eggs
Modified by imroadk1ll at 2:35 AM 8/9/2008
Old Aug 8, 2008 | 05:46 AM
noodlez1390's Avatar
Default Re: help..weird smell when driving, can only be smelled by people behind me. (imroadk1ll)
ur burning oil or u got a cloged up cat
Old Aug 8, 2008 | 08:55 AM
imroadk1ll's Avatar
so this has happened to you b4, or you just know? anyone else with this experience please tell me
Old Aug 8, 2008 | 08:57 AM
imroadk1ll's Avatar
Default Re: help..weird smell when driving, can only be smelled by people behind me. (noodlez1390)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noodlez1390 &raquo;</TD></TR><TR><TD CLASS="quote">ur burning oil or u got a cloged up cat</TD></TR></TABLE>
how do i fix those problems?
Old Aug 8, 2008 | 09:38 AM
ac_attak's Avatar
Did he see any smoke? Are you consuming any oil?
Old Aug 8, 2008 | 09:42 AM
imroadk1ll's Avatar
he saw no smoke, didnt check on the consuming oil but if it is then that means i am right how do i fix that?
Old Aug 8, 2008 | 10:56 AM
ac_attak's Avatar
Default Re: (imroadk1ll)
Go and check your oil level on the dip stick.
Old Aug 8, 2008 | 05:00 PM
imroadk1ll's Avatar
ok i just checked my dip stick and it looks fine. wat else could the problem be?
Old Aug 8, 2008 | 06:49 PM
TehGhett0P1mp's Avatar
If your smelling something funny, then it could be a clogged cat. Take it off and shake it and see if you hear a radding sound then it could be it.
Old Aug 8, 2008 | 07:34 PM
jdmjaser's Avatar
Default Re: help..weird smell when driving, can only be smelled by people behind me. (TehGhett0P1mp)
my eg does that..when i get on it..it smells really bad..
Old Aug 8, 2008 | 09:06 PM
imroadk1ll's Avatar
ya but i cant smell it. it only smells wen im on the road or moving the people behind me can only smell it i havent even smelled it.
Old Aug 9, 2008 | 01:11 AM
imroadk1ll's Avatar
ok guys got back from changing my oil. now the odd weird smell is gone now my friend says its like a burning rubber smell the same smell i started smelling right after we left his house. whats this problem now?
Old Aug 9, 2008 | 01:23 AM
angel_i's Avatar
In what conditions does the smell occur?
Old Aug 9, 2008 | 01:33 AM
imroadk1ll's Avatar
this burning rubber just started wen i shifted to first and then it continued for about 2 minutes &lt;- this is me smelling it from inside while im driving. my friend also said the burning smell started wen i started driving but i dont know how long it lasted.
Old Aug 9, 2008 | 01:44 AM
angel_i's Avatar
Check your belts and engine wiring harness in that general area. I once found a pair of scissors there, and the plastic and metal were worn down by the belts.
Old Aug 9, 2008 | 01:55 AM
imroadk1ll's Avatar
shoots thanks. does having an exhaust leak make any type of smells
Old Aug 9, 2008 | 02:03 AM
angel_i's Avatar
Is it sulphourus? Like a rotten egg smell? My b18 w/ no cat doesn't stink, it only smells a bit when i step on it.
Old Aug 9, 2008 | 02:09 AM
imroadk1ll's Avatar
just asked my friend and he said its like a rotten egg smell but that was last night but today the smell is not as thick. i dont even know wat his smelling now earlier he said it smells like burning rubber now an egg smell, i gotta find some friends who know how to drive stick so i can smell it for my self while tailing my own car.
Old Aug 9, 2008 | 02:16 AM
angel_i's Avatar
Its probably just an exhaust leak, only way to tell is to get under there.
Old Aug 9, 2008 | 02:35 AM
imroadk1ll's Avatar
aww ok thanks, so exhaust leaks can cause some stink smells then i didnt know that. i gotta fix this asap then. obtw how do i fix it?
Old Aug 9, 2008 | 03:24 AM
fin781's Avatar
you probably have some pastic melted to your exhaust. you can be going 120 and that shT will grab your cat or muffler like an STD. as far as being 160 over an oil change, no worries. ive seen guys come in my work over 10,000. the worst was 25,000 and the oil had gummed up and the car was throwing a vtec code of somesort. needless to say the engine was sludged and replaced. but go and get it done asap, you dont ned to make it a habit.
Old Aug 9, 2008 | 03:31 AM
imroadk1ll's Avatar
Default Re: (fin781)
ya changed my oil today took a while but after starting up my car seemed better until my friend told me about the smell again.
Old Aug 9, 2008 | 04:47 AM
g0tgot's Avatar
did you fart?
Old Aug 9, 2008 | 10:52 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Isn't the rotten egg smell from the clutch?
Almost positive thats what the smell was related to.
Old Aug 9, 2008 | 10:34 PM
imroadk1ll's Avatar
Default Re: (CleanLikeJdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm &raquo;</TD></TR><TR><TD CLASS="quote">Isn't the rotten egg smell from the clutch?
Almost positive thats what the smell was related to.</TD></TR></TABLE>
then how do i fix that?
