FS: ITR Rear seats, K stuff, B stuff, and more
First I will start with the usdm ITR rear seats. They are in really good condition except for one hole. $200
Next is a set of 2002 RSX Type S and 2004 TSX cams. $200 each set
Eibach K-series valve springs and retainers $200
K-swap eg/dc and maybe ek axels $150
K-series lightweight chromoly flywheel SOLD
K-series ACT heavy duty pressure plate $100
2004 TSX Drive-by-Wire throttlbody $75
2002 RSX headlights $150
MSD Blaster Coil $30
Stock B16 valve springs, retainers and keepers $50
B-series crank pulley (either an LS or B20 dont remeber) $30
GSR Intake manifold that has been polished on the outside and cleaned up on the inside. Has IACV and throttlebody gasket still $75
B16 Intake manifold basically complete. Has throttlebody, fuel rail, injectors, IACV and TPS $100
GSR Throttlebody $50
Good condition LS Valve cover $30
Set of LS cams with stock cam gears $30
B-series Rocker arms with shafts SOLD
Fuel Rail (I think its off an LS intake manifold) $20
Stock EG front seats $75
EG floor mats $50
OBD0 1-wire O2 sensor $20
Stock OBD1 injector clips $10
OBD1-OBD2a conversion harness $50
Modified by jdmintegraxsi at 1:04 PM 8/18/2008
Modified by jdmintegraxsi at 1:56 PM 9/2/2008
Modified by jdmintegraxsi at 9:47 PM 10/22/2008
EG floor mats $50
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illmatic118 »</TD></TR><TR><TD CLASS="quote">would you just sell the fuel rail, injectors?</TD></TR></TABLE>
Sure
Sure
kevs-ej1
Sep 6, 2008 12:56 PM
