Need Help on my door buzzer
Hi everyone can any one help me with my door buzzer. When i'm driving my door buzzer will just go off randomly and dosent stop its really annoying. all my doors are close and it still goes off any one know why thie happens? Also my driver side door dosent close all the way i have to SLAM it to close it. Any help would be nice thanks Honda Tech
One of your door switches that turn the buzzer on and off might have broken and its not getting pushed in all the way. That might be why it goes on and off as your driving. if you open your door you'll see them. It just like a button you can press in. Check them and if its not that it could be the wiring going to them that is not connected properly.
I'd check the door that doesn't close right first. It sounds like the door just needs to be realigned. Usually a door with time will drop down and will cause the door to not shut right. I would take it to get fixed or you could do it yourself if you feel comfortable enough to do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x4thGenCafe »</TD></TR><TR><TD CLASS="quote">You know what else is annoying ???
For the driver door check the hooks that latch on to the ring on the doorsill, it might be broken. Mine did the same thing i just switch it with a junkyard door.
check the 3 philips screws that hold the latch in place on the door. my donor civic had the problem where you had to slam the card hard enough to almost brake the glass to get it to latch... turned out two of the 3 screws were missing, and it would just move back instead of fully latching when the door would close.
