Help........... need instruction to install rear ST sway bar.
Old Aug 7, 2008 | 09:57 PM
dannyk20's Avatar
Default Help........... need instruction to install rear ST sway bar.
as stated above, this is the kit that got. I bought it use. with no instruction.
Modified by dannyk20 at 12:26 AM 8/8/2008
Old Aug 7, 2008 | 10:04 PM
CCCP-ef's Avatar
Default Re: Help........... need instruction to install rear ST sway bar. (dannyk20)
http://crxcommunity.com/viewtopic.php?t=3386
Old Aug 7, 2008 | 10:45 PM
dannyk20's Avatar
Default Re: Help........... need instruction to install rear ST sway bar. (CCCP-ef)
these pep just talking about it but no instruction. thanx tho
any else ?????
Old Aug 7, 2008 | 10:53 PM
IvIENTAL's Avatar
when you install that the handling of your car will get alot more interesting.
Old Aug 7, 2008 | 11:25 PM
dannyk20's Avatar
Default Re: Help........... need instruction to install rear ST sway bar. (IvIENTAL)
yes, rite now I'm looking at lot of under steering on my rex at auto crossing. there a couple brackets that i couldn't figure it out which way they goes.
Old Aug 8, 2008 | 01:57 AM
harmonator84's Avatar
Was thinking of getting one of these...are they REALLY worth having over stock? Why doesnt anyone get the front to go with it?
Old Aug 8, 2008 | 04:14 AM
eighty9crx's Avatar
Call up suspension techniques and ask them for an instruction guide for a CRX DX rear sway addition. They will either email it to you or send it.
Old Aug 8, 2008 | 04:21 AM
b16a1eg6's Avatar
Default Re: Help........... need instruction to install rear ST sway bar. (harmonator84)
Not the ST RSB but similar install;
The big bracket mounts to the rear tow hook holes. The little bracket mounts to the lower shock bolt(cut the welded nut off and use the long bolt and nut included)
Old Aug 8, 2008 | 08:38 PM
dannyk20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harmonator84 &raquo;</TD></TR><TR><TD CLASS="quote">Was thinking of getting one of these...are they REALLY worth having over stock? Why doesnt anyone get the front to go with it?</TD></TR></TABLE>
lot of ppl are using the 90 to 93 DA ffront stock sway bar. work very well too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a1eg6 &raquo;</TD></TR><TR><TD CLASS="quote">Not the ST RSB but similar install;
The big bracket mounts to the rear tow hook holes. The little bracket mounts to the lower shock bolt(cut the welded nut off and use the long bolt and nut included)</TD></TR></TABLE>
this kit are very nice, but pricey tho........
hmm...... i think i'm missing two nuts and bolts
yes, i emailed them, now I'm waiting for response.
Old Aug 8, 2008 | 09:17 PM
grog's Avatar
I guess you should be able to figure out everything but the endlinks. its not the same as the picture above.
The endlinks mount on the shock, using the small black brackets, they mount on the front side of the shocks, using the two longest bolts they provide.you will have to cut/pound (try a punch and hammer) the captive nuts off of the shock to be able to mount the bracket. make sure you put the bracket on so that the small tab on it prevents it from spinning, if it spins its backwards. (I notice that the tab left a little bit of play so I cut it off and welded it back on tighter).
damn theres alot to this so I'm gonna wait and see if you get some instructions, and if you dont I'll take some pictures for you.
Old Aug 8, 2008 | 09:53 PM
dannyk20's Avatar
Default Re: Help........... need instruction to install rear ST sway bar. (grog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grog &raquo;</TD></TR><TR><TD CLASS="quote">I guess you should be able to figure out everything but the endlinks. its not the same as the picture above.
damn theres alot to this so I'm gonna wait and see if you get some instructions, and if you dont I'll take some pictures for you. </TD></TR></TABLE>
i got it from ST in pdf format:
http://store.summitracing.com/...2Epdf
floridaEg8ferio
Suspension & Brakes
May 12, 2011 09:31 PM
fishnfst
Jul 4, 2003 09:46 PM
sicivic
Dec 24, 2002 05:58 AM
fubar
Sep 1, 2002 10:10 AM
swarsing
Nov 9, 2001 07:22 AM
