f22b prelude
Old Aug 7, 2008 | 07:28 PM
matthoward668's Avatar
Default f22b prelude
has anyone ever done this swap? I'm having issues with the vacuum line placement. I'm also having trouble with v-tec engaging when the engine is warm.
Old Aug 7, 2008 | 08:14 PM
mongtite's Avatar
Default Re: f22b prelude (matthoward668)
is it f22b swap with the same motor or h22.????? Some swap will have more vaccum hose or line than other, this case U just have to plug those that R not use. I'm not use about the Vtec, R U saying that if U drive Ur car right away then it works? but doesn't work when the temp is normal????? Check U oil level, make sure they are clean and up to the normal level. or not too low.
Old Aug 8, 2008 | 10:50 AM
vtecb18c's Avatar
Default Re: f22b prelude (mongtite)
yes this swap has been done tons of times... sounds like your old engine may have a bad vtec pressure switch or like was mentioned, its possible you dont have enough oil pressure...sometimes the screens in the vtec solinoid gasket get dirty and wont allow vtec to engage....i dont know if vacuum lines makes a difference with vtec i dont believe so, but 20 bucks for a haynes and a little bit of time, you can find exactly where your vacuum lines need to go...it seems like you have a pretty simple fix on your hands so im not sure why you wanna spend the money on a swap
Modified by vtecb18c at 2:56 PM 8/8/2008
Old Aug 8, 2008 | 11:27 AM
NirVTEC's Avatar
Default Re: f22b prelude (vtecb18c)
Unless I am wrong is an F22B a JDM 2.2 liter version of the USDM H23A1? I am pretty sure thats what my friend swapped into his Si because it was clean and cheap. So um yah, no vtec....
Old Aug 8, 2008 | 11:54 AM
vtecb18c's Avatar
Default Re: f22b prelude (NirVTEC)
well according to this:
http://en.wikipedia.org/wiki/Honda_F_engine
there was an f22b w/ vtec in the accord...i didnt know they came with vtec but apparently im wrong
Old Aug 9, 2008 | 12:17 PM
the vtec works fine when it's cold and stops working when the engine warms up. The oil level is normal.
I only put the f22 in because it was available and it was cheap. The h23 in it was blown.
I'm going to put an h22 in it in a few weeks.
Old Aug 9, 2008 | 12:26 PM
thanks for your help guys
03SlowZ06
Honda Civic (2001 - 2005)
10
Sep 24, 2009 06:10 PM
anht
21
Jan 4, 2007 10:42 AM
preppy79
Jun 19, 2006 11:45 PM
phateless
Oct 16, 2004 06:37 PM
