Where to get Rubber Strips? I need some... Bad...
Old Aug 7, 2008 | 05:45 PM
hotwater's Avatar
Default Where to get Rubber Strips? I need some... Bad...
Does anyone know a good solution to fixing these? They're ugly when they're chipped. I was thinking of getting new strips but I don't know the part numbers. Anyone wanna help a brotha out?
Driver's Side Door
Driver's Side Closeup
Passenger Side Door
Passenger Side Door Closeup
Bottom of Hatch
Top of Hatch
Please and Thanks
-John
Old Aug 7, 2008 | 05:53 PM
Natural Aspirations's Avatar
Sand them down and repaint them. You can get new ones from honda but they are pricey.
~$200 for the set of 4 with a decent discount
Old Aug 7, 2008 | 06:06 PM
zrickety's Avatar
Default Re: (Natural Aspirations)
looks like you don't have much left to sand on those doors. mine weren't as bad as yours and i simply painted them. when they go bad again i'm sanding mine down. $200 for trim is not in my budget
Old Aug 7, 2008 | 06:09 PM
efsublime's Avatar
i have the exact same problem. is there any easier way to chip that **** off?
Old Aug 7, 2008 | 06:12 PM
hotwater's Avatar
do you know the part numbers?
Old Aug 7, 2008 | 06:25 PM
CRX-1991's Avatar
Default Re: (hotwater)
Yea i have the same problem.
Hows a good way to get ti off the rear window???
Old Aug 7, 2008 | 06:29 PM
Chip it off..........
Look for yourself http://www.hondapartsdeals.com
Old Aug 7, 2008 | 09:02 PM
efsublime's Avatar
its not as easy as just "chipping" it off. especially when its caked on. there has to be a method like maybe heating it up? i dunno just throwing ideas out there...
Old Aug 7, 2008 | 11:17 PM
hotwater's Avatar
lol exactly. when i try chipping it off, it peels, and i dont wanna peel it to a point where the part that touches the window glass comes off with it. so basically im thinkin of using a pocket knife or something to create a straight line on the "part that touches the window glass" (sorry dont know the correct term for it) and chip away from there on down.
Old Aug 7, 2008 | 11:55 PM
zrickety's Avatar
good thought. i would use some masking tape and a sharp utility knife, then prep for paint
Old Aug 8, 2008 | 12:06 AM
guysensei's Avatar
Default Re: Where to get Rubber Strips? I need some... Bad... (hotwater)
I used a razor blade. Its small and gets under that stuff really easily just be careful. After that just clean them of and primer them. you can paint the black on top of that but i just left mine primered.
Old Aug 8, 2008 | 12:33 AM
hotwater's Avatar
Default Re: Where to get Rubber Strips? I need some... Bad... (guysensei)
howd that turn out? is it obvious that the shape differs from before you scratch it off? and how does it look? if you dont mind, do you think you could take some pics?
please and thanks
-john
Old Aug 8, 2008 | 01:28 AM
Maxcapacity's Avatar
I wonder if you were to buy a can of aircraft paint stripper, tape + cover anything & everything you want to keep! that **** is soo good. Just make sure you don't spray any on yourself - it burns!
Spray it on, wait 5min and done... Wipe off the bubbled goo they wash off with soapy water.
Old Aug 8, 2008 | 01:44 AM
turbo91hatch's Avatar
Default Re: Where to get Rubber Strips? I need some... Bad... (Maxcapacity)
I bought new ones from honda years ago and imo it was worth $60 per side. They still look brand new and are rubbery.
Old Aug 8, 2008 | 02:03 AM
hotwater's Avatar
Default Re: Where to get Rubber Strips? I need some... Bad... (turbo91hatch)
i was looking online, and found the diagram where the part should be, however, the numbers shown for the new sides are not shown on the list of parts to buy.
Old Aug 8, 2008 | 03:11 AM
Matt (SG)'s Avatar
I need new ones, but cant find the diagram. Can someone provide part #'s please?
Old Aug 8, 2008 | 05:58 AM
scottmog's Avatar
buy them, i did and i love them i got all four for about 200 bucks lol, i had some extra money a little while back
Old Aug 8, 2008 | 07:01 AM
efsublime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maxcapacity &raquo;</TD></TR><TR><TD CLASS="quote">I wonder if you were to buy a can of aircraft paint stripper, tape + cover anything & everything you want to keep! that **** is soo good. Just make sure you don't spray any on yourself - it burns!
Spray it on, wait 5min and done... Wipe off the bubbled goo they wash off with soapy water.</TD></TR></TABLE>
yeah man that would be really risky, but not a bad idea if you are careful.
Old Aug 8, 2008 | 09:14 AM
hotwater's Avatar
if you go look up CRX parts, then look under "side protector" it should show on the picture as numbers 16 and 21, but when you look on the list below the diagram, numbers 16/21 are missing. you could just maybe call the number and see if they have the part available. however, the part isnt available online.
Old Aug 8, 2008 | 10:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotwater &raquo;</TD></TR><TR><TD CLASS="quote">if you go look up CRX parts, then look under "side protector" it should show on the picture as numbers 16 and 21, </TD></TR></TABLE>
its 7 and 10
Old Aug 8, 2008 | 12:10 PM
Creator's Avatar
Yo,it is called a belt side molding(traditionally). It's #7 or 10 in the side protector catagory.
Old Aug 8, 2008 | 12:15 PM
hotwater's Avatar
Default Re: (Creator)
OH ****! sorry if i confused anyone... MY APOLOGIES!
Old Aug 8, 2008 | 01:36 PM
fireant's Avatar
You can scrape them clean with a razor, smooth them down with a flapper wheel, then repaint them with black enamel. It works fine as long as you do the flapper thing to roughen the surface then clean it really good with a prep wipe from duplicolor. You'll need to be patient with the razor part and make a clean line the preserves the part that touches the window, but with a sharp blade on a box knife, it works.
Matt (SG)'s Avatar
Ahh thank you. I found them. $47 each for my civic, I can live with that.
Old Aug 8, 2008 | 02:17 PM
efsublime's Avatar
i'm painting mine right now, i'll get pics when its done drying.
