Suspension & Brakes Theory, alignment, spring rates....
Sportline Springs
Old Aug 7, 2008 | 05:12 AM
raffaelli's Avatar
Default Sportline Springs
Anyone know what the size of a Sportline Spring is? Length and diameter?
Old Aug 7, 2008 | 05:50 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Sportline Springs (raffaelli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raffaelli &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know what the size of a Sportline Spring is? Length and diameter?</TD></TR></TABLE>
If they are springs to replace the OEM springs (Eibach Sportlines), then the diameter varies along the length of the spring. Dunno what length they are, shorter than stock of course.
Old Aug 7, 2008 | 05:59 AM
raffaelli's Avatar
Default Re: Sportline Springs (PatrickGSR94)
I have a 91 CRX Si. I am looking to goto a stiffer spring. The car has AGX with Sportline Springs. I guess I should ask what Eibach race springs fit on the AGX’s. Any idea what the lb rating is of the Sportlines?
Thanks for your help.
Old Aug 7, 2008 | 06:02 AM
Community Builder
ERS springs? Those are made for adjustable coilover use, and will not fit the spring perch on OEM-style shocks. ERS springs have flattened coil ends, so they will stand up straight on their own, and go on an adjustable coilover spring seat (also flat). OE-style springs are not flat on the bottom, will not stand up straight on their own, and the shock spring perch is shaped to match the bottom of the spring.
Old Aug 7, 2008 | 06:13 AM
raffaelli's Avatar
Ah, thanks.
Any idea with the spring rates are for Sportline Springs?
DefiantGSR
Suspension & Brakes
Nov 25, 2008 07:47 PM
janz3n
Mar 23, 2007 04:27 PM
frostwhite_92
Suspension & Brakes
12
Mar 1, 2006 09:40 AM
vincepru
Suspension & Brakes
12
Oct 14, 2005 10:48 AM
