MFactory Catch Cans/Oil Adaptors/Oil Caps/Water Adaptors/Magnetic Plugs
Old Aug 6, 2008 | 07:58 PM
MFactory's Avatar
Default MFactory Catch Cans/Oil Adaptors/Oil Caps/Water Adaptors/Magnetic Plugs
Hello Honda-Tech,
Increase your engine lifespan with the MFactory Oil Catch Can. By acting as a reservoir for waste gases (and overflowing oil during tight cornering), via the built-in oil level indicator, you can view the amount of oil that has been caught by the catch can and route the oil back to your engine sump to prevent oil starvation.
Whether you are an amateur trackday enthusiast or race professionally, installing our Oil Catch Can is a must!
- CNC Aluminum Body
- 15mm Hose Fitting
- Includes Hose & Clamps
- MSRP: $59.95 + Shipping
Precision Machined from T6 aluminum, the MFactory Oil Block Adaptor is the perfect solution for those installing aftermarket oil temperature and oil pressure gauges, or for your turbo's oil feed line.
- 3 x 1/8 point sensor holes
- Fits most Honda, Mazda/Ford and Mitsubishi blocks/filters
- MSRP: $49.95 + Shipping
Precision machined from T6 Aluminum, the MFactory Oil Cap is lightweight, as it is strong, preventing potential failure from plastic units under racing conditions.
- Unique Final Drive "Ring Gear" design
- Functional "Bolt Holes" allowing a safety wire to be attached
- Laser-etched MF logo
Increase your engine's lifespan with the MFactory Magnetic Drain Plugs. By removing metal shavings from your oil, this will prevent premature damage and increase the life of your engine. You will notice a smoother running engine and significantly cleaner oil between changes.
Do not let your next oil change go by without installing our Magnetic Drain Plugs. Our plugs replaces your stock OEM drain plug with hassle free installation. Don't rely on your oil filter to catch damaging particles in your oil - Your oil filter alone Cannot save your engine from metal shavings.
Our Magnetic Drain Plugs come with a crush proof aluminum washer to stop leaks and utilises a neo-dymium magnet which will not rust. Beware of other cheap plugs on the market with a weak magnet.
The image to the left shows our magnetic drain plug lifting an old Cam Gear, a rear camber arm (Weighing over 1.2kg!) and 2 plugs attracted to each other through a solid 1.5inch wood shelf.
Features:
- Made of extra-durable lightweight Aluminum
- Neo-Dymium Magnet that Will Not Rust
- Tested to hold over 1.3kg!
- Safety-Wire hole to meet race regulations
- Extremely cheap insurance for your engine
- MSRP (Oil Pan or Tranny Plug): $14.95
- MSRP (Set): $24.95
To order online and pay via PayPal, please click here: www.teamMFactory.com
Old Nov 14, 2008 | 11:13 PM
WRATH_TURBO_EG's Avatar
Default Re: NEW MFactory Billet "Ring Gear" Oil Caps - Very Unique - In Stock & Ready To Ship! (MFactory)
BUMP
Old May 22, 2009 | 08:49 PM
dragon007's Avatar
Default Re: NEW MFactory Billet "Ring Gear" Oil Caps - Very Unique - In Stock & Ready to Ship
bump
Old Aug 31, 2009 | 09:14 PM
UncleD's Avatar
Old Oct 16, 2009 | 11:58 AM
NightCat's Avatar
Default Re: MFactory Catch Cans/Oil Adaptors/Oil Caps/Water Adaptors/Magnetic Plugs
I just might have to snag one of those catch cans and Drain plugs
Old Jan 11, 2010 | 02:10 PM
erock77's Avatar
Originally Posted by MFactory
Hello Honda-Tech,
- CNC Aluminum Body
- 15mm Hose Fitting
Constructed from lightweight Aluminum, the MFactory Water Sensor Adaptor allows you to install your water temperature sensor with ease.
- Designed specifically for use with aftermarket water temperature gauges
- 1/8 point sensor hole fits most popular aftermarket water sensors
- Includes hose clamps
- MSRP: $14.95 + Shipping
Features:
ttt
Old Mar 29, 2010 | 08:12 AM
H23_del_soul's Avatar
Bump for a seller that MAKES their parts and doesn't just distribute BS from china, not going to mention any names, but my signature might have a clue putting in an order for 2 sets of plugs
Old Mar 29, 2010 | 08:13 AM
Do you by chance know the thread pitch of the oil plug and tranny plug for a 93 toyota 2wd pickup? if these will work for it I will take a set for it as well
Old Mar 29, 2010 | 08:20 AM
MFactory's Avatar
I think the pickups are a 12 x 1.25 unfortunately, so our plugs won't fit
Old Mar 29, 2010 | 08:25 AM
Yep, 12/1.25 damn damn damn.....
Old Mar 29, 2010 | 08:28 AM
You forgot to post a pic of the water temp sensor adapter...
Old Mar 29, 2010 | 08:36 AM
MFactory's Avatar
oh, we've discontinued those now.
Old Mar 29, 2010 | 11:51 AM
Just a heads up, it's in your original post as for sale...
EDIT:The original post from 2 years ago....wow, I'm a little behind the times here. Sorry about that. How did this get so little response?!?
Old Mar 29, 2010 | 11:53 AM
Doing any deals on the oil caps ATM?
Old May 14, 2010 | 10:41 AM
275Performance's Avatar
Placed an order online on the 12th for 2 Oil plugs and 1 trans plug
Old May 17, 2010 | 05:16 PM
Got them in today for my RSX.
Old May 28, 2010 | 01:34 PM
Beejis60's Avatar
What's the point of a transmission magnetic plug? There's already a magnet in the trans....
Old May 28, 2010 | 01:57 PM
MFactory's Avatar
The oem magnet is fixed inside the transmission, so unless you rebuild your transmission frequently, it will be so covered up in shavings/gunk that it is rendered useless.
Old Jun 24, 2010 | 11:50 PM
blivic's Avatar
Just placed an order
Old Jul 17, 2010 | 07:43 PM
01-0720's Avatar
do you still offer the oil cooler kit?
Old Jul 17, 2010 | 09:34 PM
MFactory's Avatar
The oil cooler kits are discontinued unfortunately.
Old Jul 18, 2010 | 07:51 AM
01-0720's Avatar
damnt that was a nice kit
Old Aug 7, 2010 | 03:06 PM
Magic Wheels's Avatar
Need Magnetic Plugs & Two 1-liter botlle Torco RTF.
How to order the Two 1-liter bottle of Torco RTF?
LMK, Thanks.
Old Feb 21, 2011 | 10:36 PM
ke98248's Avatar
ordered magnetic drain plug and trans plug 13 days ago, still haven't gotten anything, says it shipped
order #: 6839
Old Feb 22, 2011 | 12:57 AM
MFactory's Avatar
Could you send an email to: sales @ teammfactory.com
Thanks!
