Si treats 4k rpm as redline
hi everyone
my car has done this only 3 times so far. what happens is im on the highway for about 10 min (above 4k rpm) and then i get off wait at a light and when i start back up the car treats 4k rpm as the redline. this has been the circumstance for all 3 occurances. if i turn my car off then back on again it stops doing it. Any ideas?
thanks
thanks
if its and ep3 (aka si) your in the wrong section. check the RSX/EP3 section
if its a canadian si (aka US ex)
then its probably going into limp mode.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamescardenas07 »</TD></TR><TR><TD CLASS="quote">are you revving it when its not moving? if so there's a secondary rev limiter that engages when the car is not in motion</TD></TR></TABLE>
Not on a k20a3.
Do you have a CEL?
Not on a k20a3.
Do you have a CEL?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc5RickK20 »</TD></TR><TR><TD CLASS="quote">limp mode?
is your check engine light on?</TD></TR></TABLE>
I was thinking check engine light too.
May be a sensor that goes screwy.
Had this problem about a week ago.
your car is going into limp mode. Have you changed your oil lately? check you oil level.
I just changed my oil and it went away. Also try resetting your battery.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4angrybadgers »</TD></TR><TR><TD CLASS="quote">WhiteOnRice, 04-05 EP3s have a 5.5k standing limiter.</TD></TR></TABLE>
Blame it on my 04/05 ignorance!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ6_Hatch »</TD></TR><TR><TD CLASS="quote">/\ yep... it's supposed to be a built in launch control</TD></TR></TABLE>
I really doubt that.
doubt what?
http://en.wikipedia.org/wiki/Civic_Si
"Performance-wise, the ECU was slightly retuned to compensate for a lighter flywheel, and the launch limit RPM in neutral was dropped from 7,100 to 5,000 RPM."
I have a 2004, it's there... I just highly doubt this is what the OP's problem is
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ6_Hatch »</TD></TR><TR><TD CLASS="quote">and the launch limit RPM in neutral was dropped from 7,100 to 5,000 RPM."
7k "launch control" on an open diff FWD vehicle? LMAO. Besides, 6800 is the rev limit on 02/03, not 7100...
Please don't use wikipedia to "prove" anything. Wikipedia = opinon-pedia.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice »</TD></TR><TR><TD CLASS="quote">
Please don't use wikipedia to "prove" anything. Wikipedia = opinon-pedia.</TD></TR></TABLE>
sigh... look...
they lowered it, to 5K on the 04-05... that's how the sentence is to be read.
and like I said, I own a 04 Si, and it has a 5K limiter when you are sitting still, so I'm not using Wiki for my information, just thought I would show you that I am not just pulling it out of my *******.
sigh... look...
hey guys sorry for the lack of replies work has been a lil crazy lately.
anyway, yes the check engine light is on.
no im not reving while the car is not moving
no i dont have a CEL
ep3man: 80 on the highway in 5th is about 4k
You do have a check engine light but you don't have a CEL? If you're light is on it's like everyone is saying, limpmode. Last time it happened to me it was the O2 sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidfillups »</TD></TR><TR><TD CLASS="quote">hey guys sorry for the lack of replies work has been a lil crazy lately.
ep3man: 80 on the highway in 5th is about 4k</TD></TR></TABLE>
lmao
What do you think CEL stands for, mang?
lmao
sigh... look...
Not saying it doesn't have it. I'm saying it's not for launch control.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ6_Hatch »</TD></TR><TR><TD CLASS="quote">/\ yep... it's supposed to be a built in launch control</TD></TR></TABLE>.
sigh... look...
</TD></TR></TABLE>Not saying it doesn't have it. I'm saying it's not for launch control.
Plug in your OBD-II reader and lookup the code.
I am betting that it will be a P05XX.
Any other warning lights illuminated? Does your speedo work correctly?
Did you check the oil level?
ALSO: 5.5K works well as a launch control. Something about full RPM at idle is bad from the B-series days? Don't know.
Mfoehrkolb
42
Jul 23, 2008 07:11 PM
