Brake Shudder *help will be greatly appreciated*
Old Jul 22, 2002 | 12:54 PM
TsunamiZC's Avatar
Default Brake Shudder *help will be greatly appreciated*
ok...at high speed braking, this is hard braking from about 110 mph and up....the brakes seem to shudder, or make a slight to hard throbbing when i apply the brakes pretty hard...what do ya think the culprit would be...pads look good....is it the rotors
B2FiNiTY's Avatar
Default Re: Brake Shudder *help will be greatly appreciated* (tsunami_zc)
Warped rotors if the pads are good.
Old Jul 22, 2002 | 12:55 PM
BlueR's Avatar
warped rotors....
Dave-ROR's Avatar
Default Re: Brake Shudder *help will be greatly appreciated* (B2FiNiTY)
Most likely warped rotors
Old Jul 22, 2002 | 12:56 PM
TsunamiZC's Avatar
damn...so i'm gonna need to get new rotors now i guess ..oh wellz ,...thanks
TsunamiZC's Avatar
so will this require new rotors, or can i just get them turned
Old Jul 22, 2002 | 12:58 PM
BlueR's Avatar
you can certainly try if this is the first time...
ZygSpeed's Avatar
Try using a torque wrench and properly tightening the lug nuts to about 85 ft/lb.
Should help some, hopefully.
Old Jul 22, 2002 | 01:00 PM
Dave-ROR's Avatar
Take the rotors off and take them to Autozone. 9.99/rotor to machine them (at least here). If they are under spec just buy some autozone rotors, should be $24.99 each.
Old Jul 22, 2002 | 01:04 PM
B2FiNiTY's Avatar
Default Re: Brake Shudder *help will be greatly appreciated* (SoFreshAndSoCleanClean)
I would rather just buy some autozone rotors.
Old Jul 22, 2002 | 01:07 PM
TsunamiZC's Avatar
i'm scared to buy anything from autozone anymore....i'll see if i can get them turned ..or get some brembro blanks thanks guys for da help
Old Jul 22, 2002 | 01:11 PM
Dave-ROR's Avatar
Enjoy wasting your cash
Autozone rotors x 2000 I used to support brembo blanks and still do over anything else.. except autozone rotors.
Old Jul 22, 2002 | 01:13 PM
TsunamiZC's Avatar
so autozone rotors are pretty good then....
Old Jul 22, 2002 | 01:14 PM
Big Phat R's Avatar
Tip #1:
Don't wash your car if the brakes are still hot. This can cause rapid cooling of the rotor surface and cause warping
PB - who rarely washes his car
Dave-ROR's Avatar
Most everyone I know uses them now.. track and street.
Old Jul 22, 2002 | 01:15 PM
AssPenny's Avatar
AutoZone
Washing Car
Old Jul 22, 2002 | 01:20 PM
disordeR's Avatar
Well you should get throbbing A LOT if you have warped rotors. You should have throbbing daily driving too... I got throbbing under High speed braking on the track, but i KNOW my rotors can't be warped. So, it COULD be your ABS kicking in.
Old Jul 22, 2002 | 01:30 PM
TsunamiZC's Avatar
Default Re: Brake Shudder *help will be greatly appreciated* (disordeR)
no its not the ABS ...its only when at high speed...when i step into the brake hard, othercwise ate low speed its normal
Old Jul 22, 2002 | 01:33 PM
Dave-ROR's Avatar
My ShitSlots did the same thing.. shake at higher speeds but not lower.. and the rotors were warped.. of course they were warped new cause they ******* suck.. but still
Old Jul 22, 2002 | 01:34 PM
Big Phat R's Avatar
Cast iron rotors swell a bit when then get hot (thermal expansion) - thus you can feel more vibration. Also if the rim is slightly out of balance - this will be accentuated at higher speed.
Old Jul 22, 2002 | 01:35 PM
BlueR's Avatar
i had the EXACT same thing= warped rotors
Old Jul 22, 2002 | 01:37 PM
Warren's Avatar
Wrong-Way Wang
My car used to hop under aggressive braking. It was ******* awful. I fixed it by fixing all the busted bushings that I could find. I probably have a few more bushings that could stand to be replaced, but the swaybar ones and the endlink ones seem to have made the biggest difference.
Also, squeeze the brake, don't stomp. This made a huge difference in mine.
Warren
Old Jul 22, 2002 | 01:56 PM
yoshi234's Avatar
I shoot brides
could also be pad deposits on the rotor.
Old Jul 22, 2002 | 02:19 PM
ZygSpeed's Avatar
Default Re: Brake Shudder *help will be greatly appreciated* (yoshi234)
What kind of pads are you running?
Old Jul 22, 2002 | 02:24 PM
yoshi234's Avatar
I shoot brides
Default Re: Brake Shudder *help will be greatly appreciated* (Zygspeed)
it did this w/ the P+ on stock rotors.
also did this w/ axxis on stoptech kit.
I was told this commonly occurs after keeping the foot on the brake after getting the brakes pretty hot.
yshi - who cured both instances by taking the car to the track
