Come Wiring Gurus... Identify Please
Hey guys need some help from some of you wiring gurus... Just need help identifying what these wires are so I can fix them...
1) Location/Color Wires - Back Of Engine Bay Near Evap Canister - Black,Blue, Green, Yellow Into a Plug
2) Location/Color Wires - By The Passenger Side Headlight - Blue/Black, Black/Yellow
3) Location/Color Wires - Back Of Engine - Yellow/Blue
4) Location/Color Wires - By Resister Box - Just Checking to See if its Wired Right
5) Location/Color Wires - Below Dizzy - Green/White, Red/White, Also Is The O2 Sensor Wire Tan?
no the o2 plug is near under the dizzy with those other plugs. on the first pic is that coming out of the wire loom with the map plug? second pic is probably your fan plug since you say its missing and thats the area where it would be. the rest i cant really tell. is your car a dx or si?
pic 2 is probably the fan. pic 3 is probably the knock sensor. what motor are you using? if it's an si harness, everything should be close to the D16 components
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black0hatch »</TD></TR><TR><TD CLASS="quote">there is no knock sensor on a obd0 harness
my OBD0 b16 has a knock sensor
</TD></TR></TABLE>my OBD0 b16 has a knock sensor
yes your motor has a knock sensor what im saying is no 88-91 engine harness had a knock sensor. you would have to wire it in. besides he says he has a y7 and that doesnt have a knock sensor.
well when you convert a dpfi harness to mpfi there is a left over plug. it could be that. if all the sensors are pluged into the right plugs i wouldnt worry too much about it. ill go look at some junk harnesses i have to see if the wire colors are the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_si-r »</TD></TR><TR><TD CLASS="quote">look again 96-00 D series have knock sensors. its in the same location as a B series knock sensor.</TD></TR></TABLE>
i had a y7 in a crx and it didnt have a knock sensor but that doesnt even matter cause a obd0 ecu doesnt even look for a knock and why would you convert it to obd2 just to have a knock? a y7 runs perfectly fine on all obd0 a6 parts. anywase back to helping this guy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TweakedTT »</TD></TR><TR><TD CLASS="quote">could be yellow green ill look today thats the only think im confused about that and the plug in number 1 i have everything else taken care of already</TD></TR></TABLE>
on the first pic does that plug come out of the same wire loom as the map?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IndySporty »</TD></TR><TR><TD CLASS="quote">Isn't that the plug for the little evap control solenoid/emissions crap that was originally mounted on the firewall with the MAP on an Si?</TD></TR></TABLE>
thats what i was thinking but one his car is a dx and two if you look there is allready the other plug with the map plug.
