help! fixed my A/C now i have water in my carPics inside
so i recently bought this prelude and replaced my ac compressor. now when i drive around with my a/c on it has a small leak on the pass floor board. i thought maybe the heater core but i really dont think thats it because the water is cold so i think maybe condensation and no drain or somthing? well i was cleaning my car today and decided to pull a little door open and alot of water came out so here are some crappy pics so maybe someone can shed some light on the whole thing
There is (or should be) a drain tube that allows that water to drain out under the car. Make sure you have that tube and its not clogged up.
It is normal for that water to build up. Its just part of the a/c process. all the moisture in the car will collect on the evaporator that is inside that black box.
alright cool man thats what i figured! i would've been pissed if it was the heater core! well i guess ill go back out there and pull that carpet back to try to find that drain tube! thanks man!
look under the car for the drain tube. if u have access to a compressor blow some compressed air up there and stand back. take care of it soon because im sure ur aware wet carpet turns starts to mold and stinks liek ****.
accord-euro-r
May 1, 2002 06:40 AM
