what do I need to put type r springs and shocks on ls asap
Old Aug 6, 2008 | 08:24 AM
lil98civi's Avatar
Default what do I need to put type r springs and shocks on ls asap
ok so I need to know what I need to put springs and shocks off a integra type r onto a 95 integra ls
Old Aug 6, 2008 | 08:40 AM
neardon's Avatar
I'm a Jackass
Default Re: what do I need to put type r springs and shocks on ls asap (lil98civi)
A socket wrench and open end wrench set. Specificly 17mm, 14mm, 12mm, and maybe a 10mm. You will need a jack and jack stands are a good idea too. Dont forget the tire iron either. All that and you should be set.
Old Aug 6, 2008 | 08:56 AM
Brice.Hayden's Avatar
Default Re: what do I need to put type r springs and shocks on ls asap (neardon)
and you need the type R Lower Control Arms also. the LS ones wont work.
Old Aug 6, 2008 | 09:57 AM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
Default Re: what do I need to put type r springs and shocks on ls asap (Brice.Hayden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brice.Hayden &raquo;</TD></TR><TR><TD CLASS="quote">and you need the type R Lower Control Arms also. the LS ones wont work.</TD></TR></TABLE>
Correct.
Old Aug 6, 2008 | 05:23 PM
lil98civi's Avatar
ya thats what i was told that i need the lower control arms just wanted to make sure that was it thanks
Old Aug 9, 2008 | 12:15 PM
Slain's Avatar
i also went ahead and got new lca bolts as well.. not always needed but i had some rough experiences with lca bolts.
Zac W.
Feb 26, 2013 10:22 AM
Lazi3boi615
Jun 25, 2008 01:31 PM
pehter
Mar 25, 2008 10:31 AM
transitions
Jul 13, 2005 08:35 PM
216.226.142.95:27016
Mar 12, 2003 09:02 AM
