New 4x100 36 spline Pro Drive Hubs with ARP studs on 92-95 Civic knuckle assemblies
Old Aug 6, 2008 | 07:04 AM
2xtrme's Avatar
Default New 4x100 36 spline Pro Drive Hubs with ARP studs on 92-95 Civic knuckle assemblies
I have a pair (left and right side) of newly built 92-95 Civic knuckle assemblies with large diameter Pro Drive hubs for sale for only $200! I originally was asking for $500 for these $700 assemblies, but at this point, I just want them out of my garage! This is a great deal because the hubs alone sell for $320 from Circuit Worx (look online for yourself)! I know I could rip the set apart and sell them separately for more, but what a waste. Nobody wants these?
These knuckles have brand new hubs that accomodate the larger, 36-spline axles, such as Drive Shaft Shop Stage 3 and higher, Gator Stage 3, Prelude, or Accord axles.
These come with the following:
Honda 92-95 Civic knuckles (non-ABS)
New 36-spline Pro Drive hubs (4x100 bolt pattern)
New ARP wheel studs...If nobody wants the longer studs, I can substitute stock Honda studs
New Honda wheel bearings
New ball joints
This is the perfect combination for those with non-EX/Si Civics that want to use a stronger axle. If you can't afford the high end axles, you still get a huge strength increase by going with the OEM Prelude or Accord axles which are larger in diameter than the OEM Civic axles. Gator and DSS are just a couple examples of the larger aftermarket racing axles that will fit...I'm sure there are others. The press operations were done by an automotive machine shop. These assemblies have never been driven on. I put them together thinking they were for an EX, and didn't find out until I tried to put the brakes on...doh! My loss is your gain.
If you prefer to buy them on ebay so that you can see my 100% positive feedback rating, I can list them for you.
Thanks!
Modified by 2xtrme at 9:07 PM 11/4/2008
Modified by 2xtrme at 9:08 PM 11/4/2008
Modified by 2xtrme at 9:09 PM 11/4/2008
Old Nov 4, 2008 | 08:09 PM
2xtrme's Avatar
Default Re: New 4x100 36 spline Pro Drive Hubs with ARP studs on 92-95 Civic knuckle assemblies (2xtrme)
bump!
Old Nov 4, 2008 | 08:36 PM
4NLINE UNLIMITED's Avatar
I currently have a H22 in my EG6 right now.
Would i be able to run a set of stock Prelude/Accord axles w/ these hubs since there 36MMs? Not sure if the lengths would factor in play.
Chris.
Old Nov 7, 2008 | 10:01 PM
2xtrme's Avatar
Default Re: New 4x100 36 spline Pro Drive Hubs with ARP studs on 92-95 Civic knuckle assemblies (4NLINE UNLI
I think so, but not positive about the lengths. What axles are you using now?
Old Nov 12, 2008 | 05:01 AM
2xtrme's Avatar
If someone simply wants the ProDrive hubs and ARP studs, I'll cringe and ruin the $160 in brand new Honda wheel bearings, and sell them seperately for $200 shipped.
If anyone out there is running a non-EX/Si Civic and is shearing axles off at the hubs because you just want too much instant torque to the ground to launch out of the box like a bat out of hell, then THIS IS YOUR SOLUTION. Bigger diameter stock Prelude axles will be stronger than an aftermarket stock diameter axle built for 500hp!
Thanks!
Modified by 2xtrme at 6:09 AM 11/12/2008
Old Nov 12, 2008 | 05:36 AM
dplatt's Avatar
I'll vouch for this guy. Quality parts and super fast shipping. You can't get better. Too bad these won't fit my car.
Old Nov 26, 2008 | 05:12 AM
2xtrme's Avatar
bump for amazing price!!!
Old Dec 25, 2008 | 09:33 AM
2xtrme's Avatar
These things are still for sale. Doesn't anyone still run all motor with a stiff clutch and slicks so that they break axles on demand like I used to. Once I switched to the bigger diameter axles on the EX caliper version of these knuckle assemblies, breaking axles is a thing of my past. Maybe there are just too many low torque off the line turbo junkies, or people that don't mind losing power right out of the gate.
Old Dec 28, 2008 | 03:42 AM
2xtrme's Avatar
bump every week until I can get rid of this things.
Old Jan 4, 2009 | 04:10 AM
2xtrme's Avatar
Old Jan 4, 2009 | 07:15 AM
Fibercation's Avatar
wonder if these would work on my willwood set up..... i think so
Old Jan 5, 2009 | 05:49 AM
2xtrme's Avatar
If you have non-EX/Si knuckles now, then they should bolt up just the same. Interested?
Old Jan 7, 2009 | 07:23 AM
2001B18C1GS-R's Avatar
wanna sell just the arp studs ill take them pm me
Old Jan 7, 2009 | 09:43 AM
2xtrme's Avatar
You mean the studs and hubs, or just the studs? If the price is right, I'll part anything out. I'm getting close to ripping the whole thing apart to do so anyway. I just hate to ruin those brand new Honda wheel bearings. Best way to contact me is via email at davidplatt01@comcast.net. Thanks.
Old Jun 1, 2009 | 02:42 PM
vu337's Avatar
are these still for sale? will they fit 95 integra gsr calipers? with abs.
2xtrme
Dec 24, 2008 05:36 AM
tolowhb
Feb 13, 2004 02:56 AM
