something wrong with my ls/v...help me outt
i jus finished puting my ls/v into my 98 integraaa....and my vss and alternator doesnt work.....but my rpm doess and my speedometer doesnt...i read up on sum stuff about this problem and i cheked my vss/alternator fuse alreadyyy and it was finee...so i guess i need a new alternatorr and a vss plug??
Modified by wowy978 at 4:30 AM 8/6/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wowy978 »</TD></TR><TR><TD CLASS="quote">i jus finished puting my ls/v into my 98 integraaa....and my vss and alternator doesnt work.....but my rpm doess and my speedometer doesnt...i read up on sum stuff about this problem and i cheked my vss/alternator fuse alreadyyy and it was finee...so i guess i need a new alternatorr and a vss plug??
Modified by wowy978 at 4:30 AM 8/6/2008</TD></TR></TABLE>
Double check all of your connections. If there all connected then verifiey the colors of the wires and reference them to the colors of the wires running to each plug in the factory manual for your vehicle to make sure you didn't mistakenly plug any similar plugs in the wrong place. If thats all correct then check all of your fuses and follow the manuals procedure for trouble shooting.
civcexcoupeblack
May 31, 2003 10:02 AM
