Touch Up Paint For Left Passenger Door
Old Aug 5, 2008 | 09:14 PM
gu17dam005's Avatar
Default Touch Up Paint For Left Passenger Door
Hi there I drive a 2006 Cr-v Lx. I recently banged up my left passenger door while backing out of a driveway. It was open and it got caught on the wall so I took it to the shop to fix it. They bent most of the metal back together and it works fine now. The problem is, that there is a line of chipped and scratched paint running down the door about 3 inches long and 1 inch wide. The paint is not totally chipped off, its sort of in pieces. I was wondering what i could do. I've looked up touch up paint, but i was wondering if i need to remove it and prime it, then paint it, and clear coat it, or if i can just apply the touch up paint. Any suggestions will be of great value.
Modified by gu17dam005 at 2:02 PM 8/6/2008
Old Aug 6, 2008 | 03:46 AM
RoadRage212's Avatar
Default Re: Touch Up Paint For Left Passenger Door (gu17dam005)
Looks like they've already applied touch up paint to it so that it won't rust. Unfortunately, this is as good as its going to get unless you do bodywork and paint the whole door.
Old Aug 6, 2008 | 01:03 PM
gu17dam005's Avatar
Default Re: Touch Up Paint For Left Passenger Door (RoadRage212)
Is there anything i can do to make it less noticeable. I dont even think its the same coat of paint... If i actually got the Alabaster Silver, would it make a difference or am i doomed with an ugly left passenger door?
Old Aug 7, 2008 | 03:27 AM
Well the only option you have is to remove their touch up paint and re-apply your own. It should be fresh so use some thinner to remove what they've applied. When you apply your own stuff keep it 'between the lines' if you know what I mean. That should help but it would take a surgeon's hands and an artisitc talent with a brush to get it much better than what they've done.
Old Aug 8, 2008 | 12:48 PM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
That's fugly.
I wouldn't tolerate that on an 06. Bring it some place to get done, or give it a shot yourself. Sand, primer, body filler, paint, sand, paint, sand, paint, clear, maybe sand, clear.
Davidss
Paint and Body
93
Aug 18, 2010 05:27 AM
hondacivic44
Paint and Body
Aug 27, 2007 11:57 AM
blk007
Apr 28, 2007 10:59 PM
imitati0n
28
Jun 27, 2004 09:34 AM
