Tranny case cracked, I'm I screwed???
Old Aug 5, 2008 | 05:55 PM
Red_ED8's Avatar
Default Tranny case cracked, I'm I screwed???
Well to make a long story short, I wrecked my SI crx about 6 months ago. I messed up a lot of stuff in the wreck but have just about fixed everything or so I thought. I went to clean up my tranny a bit and noticed a crack in it, not huge but it's still cracked. This is a couple pic's of the crack:
[IMG][/IMG]
[IMG][/IMG]
[IMG] [/IMG]
Now I know the tranny can brake down into 2 pieces, can I use the outer case from a DX tranny and swap it with the SI's? or can this be welded up?
Old Aug 5, 2008 | 06:00 PM
GLI's Avatar
GLI
Default Re: Tranny case cracked, I'm I screwed??? (Red_ED8)
Open her up and make sure everything looks awesome and swap cases.
Old Aug 5, 2008 | 06:03 PM
fireant's Avatar
Default Re: Tranny case cracked, I'm I screwed??? (GLI)
If its not leaking fluid, then you'll have some time to find a scrapper case to swap everything into...physically its not too hard, but I wouldn't do it alone because there are alot of parts to keep track of. The toughest bit is the order of what goes in/out and getting the gear selectors all in order.
Modified by fireant at 9:10 PM 8/5/2008
Old Aug 5, 2008 | 06:10 PM
Red_ED8's Avatar
Default Re: Tranny case cracked, I'm I screwed??? (fireant)
Awesome, that's what I was banking on . I got a DX tranny just laying around so I can use that case.
Old Aug 5, 2008 | 09:00 PM
traxxasx's Avatar
Just have somone weld it up.
Old Aug 5, 2008 | 09:43 PM
gsrpedro's Avatar
ur good men if ur tranny its running good dont worry about or get someone to weld that ****
SIR1.6CRX
12
Mar 14, 2010 07:43 AM
norm13
Jan 23, 2006 03:22 PM
The G2 Racer
May 2, 2004 08:51 PM
Toptul_Honda
Jan 1, 2003 06:04 PM
