Help?!?!
Old Aug 5, 2008 | 05:12 PM
ramoyer1's Avatar
Default Help?!?!
OK I know I didnt look hard enuf. I have a 1991 honda 1.5 (got today).I want to know how to make more power out of that motor or what motor would just bolt up in there without many problems?
Would my 1.5 hold a turbo? if so how much psi could i run?
I need to know about motor mods!!
Sorry i built chevy v8s and eclipses. Hondas are new to me!
Old Aug 5, 2008 | 05:27 PM
vtecb18c's Avatar
Default Re: Help?!?! (ramoyer1)
whats your budget?
Old Aug 5, 2008 | 05:29 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Help?!?! (vtecb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c &raquo;</TD></TR><TR><TD CLASS="quote">whats your budget?</TD></TR></TABLE> goals, any laws rules you have to meet?
Old Aug 5, 2008 | 05:56 PM
ramoyer1's Avatar
Default Re: Help?!?! (***$nyper)
I really dont wanna change the motor and I can spend pretty much any thing. I just want to make it have more power!
Old Aug 5, 2008 | 06:19 PM
vtecb18c's Avatar
if you have the money, swap the motor....you'll spend a lot of money on a little 1.5 to achieve a goal that could have been acomplished much cheaper with a motor swap
Old Aug 5, 2008 | 06:29 PM
northemt88's Avatar
if you have enough and you dont want to swap the motor yourself the go to a shop, any b-series will be good, if you really have the money go k20 or h2b, how are you talking about having?
if i had an actual number then i could give you a better idea, how much power are you looking to make?
Old Aug 6, 2008 | 02:04 AM
ramoyer1's Avatar
Default Re: (northemt88)
Wat about a d16 v-tec outof a 94 honda?? What will that take to bolt in and make it run?
Or a b18A1 what will i need there
Old Aug 6, 2008 | 10:31 AM
northemt88's Avatar
Default Re: (ramoyer1)
what model is you car
d16's are ok but for the same time and energy you will be able to put an ls fo like $40 more,for an ls into your car about roughly $400-500, so i would say stay away from sohc not really worth it in my opinion,
all you have to do is go to a local pick your part yard or ebay and get a pr4 ecu and get 4 fuel ingectors for obd0 and a reistor box little ridgged box in the drivers corner of the engine bay usually, every thing else will plug and play, except you have to switch 2 wires on the dizzy now it will run, get da manual axels and half shaft and shiftlinkages,
all that maybe $100 for a pick your part
this is really the best bang for your buck
p.s. you also need mounts, check ebay sometimes they have mount and axle combo deals
Old Aug 6, 2008 | 10:35 AM
funouse1989's Avatar
i say u swap and dont waste money on something thats not going to produce that much power. if your going to spend your money, save up and spend it right, it will pay off in the long run.
Old Aug 6, 2008 | 03:36 PM
ramoyer1's Avatar
Default Re: (funouse1989)
It is a 4-door the only reason i was asking was because my firend has a 1.6 vtec-e motor with trans for 500 the only problem is the hardness is a lil messed up.
Old Aug 6, 2008 | 03:41 PM
northemt88's Avatar
its not a terible motor but my friend has one and he has tried to build it up and its not as fast as my other friends ls stock, so its not terible if your going to boost then sure but for the $ to HP argument there are some definite limitation to the singles
how much power are you looking to make, what do you plan to do with it
Old Aug 6, 2008 | 03:50 PM
Zaakro's Avatar
those Vtec-e motors are not the great its good if you want vtec and you want good gas mileage
Old Aug 6, 2008 | 04:55 PM
ramoyer1's Avatar
Default Re: (Zaakro)
I just want some getup and go! i picked up the car today and it spin tires (a lil) in 1st and 2nd gear. from the looks of it that 1.6 will bolt right up. but for some reason i do have a ps pump on the stock motor. what will it take to put that 1.6 vtec in my car?
Modified by ramoyer1 at 6:38 PM 8/6/2008
Old Aug 6, 2008 | 06:37 PM
gearhead16's Avatar
put out the cash and do a b swap there real simple and u get alot more power than your engine
Old Aug 6, 2008 | 07:02 PM
crxsirg's Avatar
Default Re: (gearhead16)
You know you really should try searching first...and not just honda-tech, even google will bring up tons of info pertaining to your questions. Knowledge is your friend...go forth and empower yourself!
PR_purpleDb7
Oct 16, 2008 02:11 PM
jdmep
10
Jun 26, 2008 05:25 PM
4dr_tony
10
Jun 7, 2006 02:12 PM
nicrom
Honda Motorcycles
Dec 27, 2005 05:43 PM
93egbeau
May 9, 2003 12:04 PM
