no spark
Old Aug 5, 2008 | 02:12 PM
Prelude_lunatik's Avatar
Default no spark
I have a 92 prelude sr with a 96 h22a1 engine it was running after i did the swap then i took it off the road for the winter. I went to start it up agian and now there is no spark. I can hear my fuel pump and smell the gas but it wont start. it tries to turn over but nothing, im not sure what could be casuing this, i have recently put a new high flow fuel pump and a new tps sensor and new o2 sensor on. If anyone one has any suggestions that would be appreciated
thanks,
Old Aug 5, 2008 | 03:09 PM
vtecb18c's Avatar
Default Re: no spark (Prelude_lunatik)
possibly the ignitor in the dizzy
Old Aug 5, 2008 | 03:10 PM
vtecb18c's Avatar
someone just had a simular problem and it was the coil so you may wanna check that out also
Old Aug 5, 2008 | 03:18 PM
vinuneuro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude_lunatik &raquo;</TD></TR><TR><TD CLASS="quote">I have a 92 prelude sr with a 96 h22a1 engine it was running after i did the swap then i took it off the road for the winter. I went to start it up agian and now there is no spark. I can hear my fuel pump and smell the gas but it wont start. it tries to turn over but nothing, im not sure what could be casuing this, i have recently put a new high flow fuel pump and a new tps sensor and new o2 sensor on. If anyone one has any suggestions that would be appreciated
thanks,</TD></TR></TABLE>
Take the wire going to the distributor and see if you get spark. If you don't it's the ignition coil. If you do, test the distributor and icm.
Old Aug 5, 2008 | 10:33 PM
mongtite's Avatar
Default Re: no spark (vinuneuro)
ignition coil is very common problem.
wanna_run
25
Feb 7, 2012 09:11 AM
littlered06
Dec 3, 2010 03:58 PM
manekDC2.
Apr 22, 2006 11:31 AM
vietjdmboi
Mar 8, 2005 06:33 PM
JoeCDN
15
Jul 13, 2004 06:36 AM
